Thanks for the info. It sounds like with a torque curve that flat, We should be able to use higher gearing for crusing purposes - I suspect true horsepower, which is proportional to torque X RPM, becomes the limiting factor and not actual torque. (If I am remembering those old dynamics and physics formulae correctly)
I think that for steady crusing, we need to find out the road horsepower required to maintain say, 80 MPH and check the HP curves to see at what RPM we fall below the road horsepowder needed. Road HP could be calculated by mass and coast-down tests (how many Gs) or perhaps we can ask one of the ECU-mapping brethren to tell us via boost or specific fuel consumption, etc. what the instantaneous HP is when road testing at 80 MPH.
We could then use documented HP curves to see how low of an RPM we can produce the same HP (with more pedal, of course)
How high of gearing can we go in 5th for near-flat crusing. I bet with enough pedal and stock ECU, we could cruse at 80 MPH as low as 1900 RPM.
Any ideas? Sounds like a thesis project.
I want to ask our non-Northamerican brethren how their crusing RPM compares to ours. Maybe VW uses different gearing in Europe or across the globe. I will start another topic for this one.
