DieselDuberrr
How Bad is it guys??? Im starting my research and price checking to get all this done.
I did my glowplug harness, I have the glowplugs so they're on the list. I guess im confused about the engine stuff mostly. n75 and such...
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSP29M43M****** Mileage: 291750km-181285miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000AG 4308
Coding: 00001
Shop #: WSC 00066
VCID: 629D5763CD5950D704C-4B1E
3VWSP29M43M153551 VWZ7Z0C6856419
4 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 35-10 - Electrical Fault - Intermittent
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 35-10 - Electrical Fault - Intermittent
17964 - Charge Pressure Control
P1556 - 35-10 - Negative Deviation - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
Readiness: 1 4 0 0 0
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 MK
Component: AG4 Getriebe 01M 5023
Coding: 00000
Shop #: WSC 00000
VCID: 05576CFF3C37C7EF41E-0962
No fault code found.
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 3333E2272723895FBFA-5184
Part No: 1C0 909 605 A
Component: 1N AIRBAG VW51 02 0006
Coding: 12622
Shop #: WSC 00066
VCID: 221D17638DD910D744C-513C
3 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance Too High - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
01217 - Side Airbag Igniter; Driver Side (N199)
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 806 M
Component: KOMBI+WEGFAHRSP VDO V65
Coding: 07332
Shop #: WSC 00000
VCID: 313FE82FD83FBB4FCD6-513C
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: 70B92D2B13B5F247828-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 372BD637365B657F832-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0009
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-00 - Incorrectly Equipped
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 D
Component: Radio ZSW 0010
Coding: 00401
Shop #: WSC 00066
VCID: 211F186F88DF0BCF5D6-513C
2 Faults Found:
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
00879 - Connection to Speaker Front Right
44-10 - Short Circuit - Intermittent
End----(Elapsed Time: 05:26, VBatt start/end: 12.8V/12.6V. VIgn 0.0V)------
75 76
Coding: 00001
Shop #: WSC 00066
4 Faults Found:
Coding: 00000
Shop #: WSC 00000
Coding: 0004097
Coding: 12622
Shop #: WSC 00066
3 Faults Found:
Coding: 07332
Shop #: WSC 00000
1 Fault Found:
Coding: 00006
Shop #: WSC 00066
Coding: 00258
Shop #: WSC 00066
1 Fault Found:
Coding: 00401
Shop #: WSC 00066
2 Faults Found:
