Bkcorso
Okay, (2003 beetle alh)so the brake pedal gets very stiff after a few uses. I hooked up a vacuum gauge and it shows the vacuum dropping off rapidly after the brake pedal is released and it slowly builds back up to about 25hg. Now if the pedal is pressed hard and released repeatedly by about the 4th release the vacuum gauge is near zero and the pedal is a stiffy. The vacuum will slowly build back up and I can repeat the process. I hooked up the vacuum gauge to the tee off of the main booster line and have both n18/n78 disconnected and plugged. If I shut off the car it will hold vacuum (30 mins and no change)
This to me leaves two items, the booster or pump. Is there a way to test either ? I did the same test on my golf and the vacuum never dropped, and when I created a leak and plugged it up the vacuum recovered twice as fast and to 30hg.
