priest
2004 BHW 2.0 TDI build thread
I bought a 2004 passat with the 2.0 BHW tdi with 154,329miles on it that had thrown a timing belt and mated a piston to a valve. So pulled the engine and started rebuild. Started out just doing a head job, new gaskets, timing belt kit, and standard pistons. Got it apart and it needed a full rebuild. had the head done and bored the block .5mm over. rebuilt the injectors. polished the crank, counterbalance shaft delete, rebuilt turbo.
Keep in mind I bought the car in February 2014 and its now August 2014 and the car still isn't back on the road. It took 2 machine shops and months to get them to work on it. finding anything for this engine isn't easy. I would be more than happy to lend anyone a hand that wants to tackle this task. I've found out the hard way where to and no to buy parts and where you get the best deal. I've dropped about 6k into the engine because once you get started its hard to stop right?
I ordered my pistons, valves, valve springs, and head gasket kit from hansdieselparts.com
I ordered the timing belt kit, counterbalance shaft delete kit, injector rebuild, rod and main bearings from kermatdi.com
Had the turbo rebuilt by Turbo Supply the turn around was amazing it took them 2 days to have it back in my hands with a 1 year unlimited miles/hours warrant.
Looking for the best place to get a tuner for the 2.0 haven't heard much about anyone besides Kerma.
I'm trying to figure out the easiest/cheapest way to do the egr delete.
The first stop for the car after its running is muffler shop for 2.5in straight pipe from the turbo back. Later mods are a stage 2 cam, studded, bigger turbo, and manual swap.
I know this isn't the best thing to read but if you have any questions feel free to ask away. I'll keep this updated when I get time to work on it. Thanks for reading have a good day
