eh, I'll chance it, 'sjust metalI've only heard bad things about those Chinese 12mm heads. One story about them destroying an engine.
There are many things that can cause such a situation.The daft think that turning the igniftion off will stop a runaway. It wouldn't be called that it avoid it were as simple. You'll have to stall the engine with a high gear to shut it off.
The camplates are different, the automatic pump had a more aggressive profile and more lift. I think this can be found at the forum as well, look for DE143 or DE110.Can anyone confirm that the 10mm and 11mm camplates are the same or different?
Nice guess, but 100% wrong...[486] - you're not correct on this one. You can drive quite a ways on just the fuel inside the pump itself with the shutoff solenoid off.
I've driven several miles this way before (about 2 miles one time and about 5 another). I had a switch intercepting the shutoff solenoid and the wire broke off.
The reason the engine shuts off nice and quick with the key isn't due to the shutoff solenoid, it's because the ECU drives the QA to zero. If you disconnect power from the shutoff solenoid while the engine is running under ECU control, it'll keep running for a little while (much more so if you keep the revs up) since as the RPM's drop, the ECU is commanding more QA Position and it will pull a void inside the case (or pull air past the shaft seal or any other place it can) and keep running on the fuel inside the pump.
If you experience a runaway for any reason whatsoever - NEVER push the clutch in - it won't always re-engage a fully fueled engine at high RPM/high load. Just leave it in whatever gear it's in and stand on the brakes. The brakes are WAY more powerful than the engine could ever hope to be and will bring it to a stop the quickest.
There is more to it than just swapping pump heads, there are multiple shim points that MUST BE ADJUSTED or you WILL SEIZE THE PUMP!Hi,
I have looked through several threads on here and other sites but cannot find the answer...
I have a spare 10mm pump (Audi) and a spare 11mm pump head on a Bosch pump for a Renault rustbug. These I understand are interchangeable.
Is the conversion from 10mm to 11mm a DIY prospect or is to best left to a specialist?
I also get the impression that there is a lack of power with this hybrid over a full fat 11mm pump but is there much of a loss in performance over the 11mm genuine article?
Thanks for any suggestions....
FF
X 2, cant justify 1000 on installing 12mm Head on a running 11mm pumpIs there any documentation on the web which explains the shimming procedure? I searched extensively a while back and got nothing
So, I must be missing something here because my theory is such that it wouldn't ever shut off with the fuel shutoff solenoid which I'm guessing is not correctNice guess, but 100% wrong...
The ECU in fact uses the Shut-off solenoid as the primary kill switch for the injection pump.
The ECU command the Solenoid to energize (which is why your engine will die when the alternator and battery are dead) unlike older engines like the MB that have a manual cut-off (fail operational design).
Let's follow the path of the fuel so you guys understand how the injection pump works...
Fuel is suction fed from the tank to the injection pump housing where it is pressurized to around 110-130 psi. This positive pressure mitigates cavitation and assists the filling of the high pressure plunger port.
Positive fuel pressure also controls timing advance (Hydraulically), but thats another subject.
Fuel exits the top of the central chamber via a feed channel that leads to the Fuel Shut-off Solenoid (kind of why its called that...)
The Solenoid when energized uncovers the feed port leading to the inlet port of the high pressure plunger chamber.
As the High pressure plunger reciprocates and rotates in the bore, it aligns with the specific feed port that fuel is pumped under high pressure to.
When you shut the engine off, the Fuel-Shut off Solenoid, is spring loaded to CLOSED and blocks all fuel from entering the high pressure chamber and the engine shuts down immediately.
The Quantity adjuster only comes into play during over-run when the engines RPM's are being sustained, thus the Quantity adjuster is commanded to zero, however this is not a perfect adjustment so positive cut-off of the fuel cannot be assured so this is simply a means to control load ONLY with no other associated function in the VE fuel system.
In a runaway situation, the Quantity adjuster by default will show "0" since this interpreted as a "Over-run" condition and normal in the context of diesel operation.
Again, the Fuel Shut-off Solenoid is the PRIMARY and SOLE means of shutting a TDI with the VE pump off.
http://www.vwdiesel.net/forum/index.php/topic,6427.30.htmlIs there any documentation on the web which explains the shimming procedure? I searched extensively a while back and got nothing
in the time that the spill port is open to the pump case there can't be any pressure built to open the DVs much less the injectorsWhat am I missing?
Really? Was I off topic by also asking DIY info on pump swaps? Don't expect too many reply if your rude.Hi,
FF
I revise my answer to "no, take it to a pump shop"The thread has been totally hijacked by yourselves arguing over something which has no bearing on MY original Posting.
