Old February 26th, 2020, 15:07   #1
gbrandt
gbrandt's Avatar
Fuel Economy: 64/50/37
Default VCDS Works but ScanGauge does not
Hi,
I have an ASV 1.9 TDI installed in my Vanagon (T3). I have a scangauge that simply will not connect to the ECU. Actually I have two, one much newer than the other and they both do not connect.
I have a VCDS (Vag-com) that connects perfectly well.
My used pins on the OBDII connector are 4, 7, 15 and 16
I have tried forcing KWP protocols with no success. Any idea on what may be going on?
Thanks,
Gregor
gbrandt is offline   Reply With Quote
Old February 27th, 2020, 02:41   #2
Rxfire
Rxfire's Avatar
Fuel Economy: 41-44 at 75 mph w/ no a/c
I fried a ScanGuage hooking up to a TDI with an aftermarket radio in it. Do your ScanGuages work on other cars? Mine would not work at all after that incident.
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old February 27th, 2020, 10:53   #3
gbrandt
gbrandt's Avatar
The scangauges do work on other vehicles.
I am now thinking that it's the missing ground on pin 5.
Someone has also told me that switched power to pin 1 is also required but I see no evidence for this elsewhere.
Old February 27th, 2020, 12:30   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I do not have any help for you other than to say (and you probably already knew this) that VCDS uses the native VAG protocols and connections at the DLC. A Scangauge (or any other generic OBD2 device) will only use the generic part of the DLC.
This may help you decipher what you need and what is missing:
https://en.wikipedia.org/wiki/On-boa...stic_connector
oilhammer
www.cardocautomotive.com
Old February 27th, 2020, 13:20   #5
gbrandt
gbrandt's Avatar
Ok, I can see the VW used pin 1 for switched power, but odds are very good the ScanGauge would not use that since the ScanGauge is a universal product. I'm putting my money on grounding pin 5. Will update after I've done that.
Gregor
Old May 22nd, 2020, 16:38   #6
gbrandt
gbrandt's Avatar
Ok, grounded pin 5 and still no success. No idea whats going on now.
Old May 23rd, 2020, 08:30   #7
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
Why not contact the people at Scangauge and ask them?
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.Scangauge II
Jetta_Pilot is offline   Reply With Quote
[VCDS] N/A displayed in mesure block (and so on TDI grap) but advanced mesure works ! bigboss59400 OBD Scanners 3 November 28th, 2015 14:25
WTB: VCDS and FS: Scangauge II Slowrvr Ontario 11 August 1st, 2013 08:46
VCDS No response from Contoller, but SnapOn code reader works AARodriguez Corp. OBD Scanners 13 December 15th, 2012 18:20
HELP: New Macbook Pro 2012 (USB 3.0) + VCDS + Fusion no longer works SFHGolfTDI OBD Scanners 22 November 11th, 2012 14:57
ScanGauge and VCDS question AndyBees OBD Scanners 0 September 21st, 2011 08:05
Page generated in 0.14182 seconds with 11 queries
[Output: 81.72 Kb. compressed to 70.99 Kb. by saving 10.73 Kb. (13.13%)]
