Old August 6th, 2019, 08:39   #1
rhinorear
TDI(s): 2014 JSW
Default OBDeleven & Fuel Filter Change
Hi All. 2014 Jetta TDI SW newb here. With the ODBeleven set up am I able to cycle my fuel pump to prime the fuel filter canister after a filter change?
Thanks!
rhinorear is offline   Reply With Quote
Old August 6th, 2019, 09:02   #2
JSWTDI09
JSWTDI09's Avatar
I'm pretty sure that ODB11 can do "basic settings". This is all that is necessary and you could test it any time. Go to the engine controller (01) and go to basic settings. Enter 35 (basic setting #35) and you should be able to turn the electric pumps on and off. You can test this before replacing the filter because you can hear the pumps turn on and off. To do this you will want the ignition on but the engine off.
Have Fun!
Don
1966 MGB Roadster (just for fun)
JSWTDI09 is offline   Reply With Quote
Old August 7th, 2019, 07:48   #3
rhinorear
TDI(s): 2014 JSW
Sounds like a plan. I've got to purchase the dongle first. Thanks Don!
Old August 7th, 2019, 09:55   #4
JSWTDI09
JSWTDI09's Avatar
Originally Posted by 35 Yr Dsl Veteran View Post
You can just manually fill fuel filter most of the way with fuel.
True, but if you have a tool to run the pumps, there is no reason NOT to use it. Having VCDS, ODB11, etc. is not a bad idea for any VW owner.
Have Fun!
Don
Old August 18th, 2019, 11:38   #5
rhinorear
TDI(s): 2014 JSW
Thanks Don, and I did have fun. Your instructions fit to a tee and I was bale to toggle the fuel pump on and off.
Had a big ol **** eating grin on my face. Trying to learn both this tdi and a Jeep JKU and its proving to be a challenge for this Luddite.
Where are you getting your setting number info from? Any suggestions as to how to turn the horn off when you lock the car?
Old August 18th, 2019, 14:36   #6
JSWTDI09
JSWTDI09's Avatar
I have VCDS and a lot of the info is "built-in" (one weakness in ODB11), also Ross-Tech has a forum and a wiki. Aside from these sources forums like this one and VWVortex (and others) have lots of info once you figure out how to search for it.
I'm not sure about your car. On my Mk5 (2009) there was a setup option called "ATA Confirm" and it could be turned on and off from the MFD. If that option does not appear in your car, I'm sure it can be done with ODB11 but I do not know how. (P.S. ATA = Automatic Theft Alarm).
With VCDS the long coding helper would probably tell me how to do it, but that is of no help for you. I'll bet there is an ODB11 forum with lists of lots of things you can change.
Have Fun!
Don
Old August 18th, 2019, 16:26   #7
Lightflyer1
Lightflyer1's Avatar
FYI: I once took apart fuel filter for my '98 Jetta TDI at 10K miles. The top 1/2 of the pleats were 100% pristine white clean, so I went to 20K intervals after that.
I don't know about 1998 but since 2000 it has been 20k mile change intervals as published in the VW maintenance cards.
FS: OEM Oil Change Service Kit & Fuel Filter GelbVR6 Private TDI Items for Sale/Wanted 0 December 10th, 2017 10:13
AHU no start after fuel filter change & turbo/intake removal Sodie82 TDI 101 34 April 17th, 2016 19:12
start & stall after fuel filter change Kafvt VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 May 14th, 2015 19:42
Fuel Filter change, primed filter, ran for 30 seconds JetFixxxer VW MKIV-A4 TDIs (VE and PD) 1 September 7th, 2013 08:04
What R the Tools needed: Fuel & Air Filter change? 1930_Model_A_Cpe TDI 101 2 March 30th, 2004 22:01
Page generated in 0.14070 seconds with 11 queries
[Output: 82.13 Kb. compressed to 71.25 Kb. by saving 10.88 Kb. (13.25%)]
