Old January 1st, 2019, 11:05   #31
BarryT82
You don’t need vcds to change the fuel filter in this car. Just turn the key a few times and the system will fill the canister.
BarryT82 is offline   Reply With Quote
Old January 1st, 2019, 12:48   #32
KeyTDI
Originally Posted by BarryT82 View Post
You donít need vcds to change the fuel filter in this car. Just turn the key a few times and the system will fill the canister.
Good to know.
I have Liqui Moli Diesel Purge, and Diesel Klean on hand... read that I could fill the canister with that and do double duty Clean!
Anyone know if this kit has the tools I need to do the Timing belt?
https://www.amazon.com/8MILELAKE-Eng...ing+belt+tools
We have a Audi with a TSI in the family too, so i'd like as much specialized tooling as possible!
The only thing I didnt see in this kit was the Cam Counter holding bar for loosening Cam and HPFP pulley.
I have Steel, MiG and TiG, as well as a lathe....
The CD changer is clicking and wiring constantly... even after I take the key out, so thats gotta come out soon!
KeyTDI is offline   Reply With Quote
Old January 1st, 2019, 13:21   #33
KITEWAGON
KITEWAGON's Avatar
Are you sure? I remember using VCDS to cycle the fuel pump and I thought that it was necessary. But its been years since I changed a fuel filter and perhaps that step was unnecessary.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old January 1st, 2019, 13:25   #34
BarryT82
Yes. Iíve owned a few of these vehicles. With the Audi Q5 TDI I had to use VCDS to refill the filter, but it wasnít a drop in filter.
Old January 1st, 2019, 15:35   #35
KeyTDI
Pulled the Head unit out, as the whirring and clicking noise was diving me nuts... well, more nuts!
Took the top off the unit.
Both ends of the ribbon cable seemed attached well...
Disconnected, it from the main board and took the changer out.
I can see at least 1 CD in there, but have not disassembled further.
Questions:
Anyone have any ideas?
Can I put the unit back in without the CD changer inside?
Old January 1st, 2019, 17:40   #36
BarryT82
Questions:
The radio will work without the cd changer, but if you press media itíll give you the cd error. There are a few cables on the bottom of the changer itself. Disconnect those and reseat them.
Old January 1st, 2019, 18:50   #37
Geordi
Geordi's Avatar
Location: Somewhere between Heaven and Hell. But it is really hot here in S. Florida...
Was the CD in it any good?
Or was it something like "The Greatest Hits Sung By William Shatner"
I always knew beans would give me gas. But I never expected Diesel!
Geordi is offline   Reply With Quote
Old January 2nd, 2019, 15:53   #38
KeyTDI
The cables looked fine, but as I have a 200 mile round trip today, I just slipped the unit back into place and, as Barry stated, it worked fine!
My T8 Torx bit grew legs, so I have ordered a new set and will disassemble the CD unit further and see if I can see anything wrong with it when they arrive!
No idea what the CD is... I can only see the edge of it!
Oh, the excitement!
I ordered the Timing tool set as above, and will see what the story is when it arrives.
I can make a cam/HPFP hold tool if I need to.
Seems my oil filters are lagging in shipment, so I have to wait before U start the big service.
Talking of service....
This the the Air filter that is in currently...
Old January 3rd, 2019, 06:18   #39
KITEWAGON
KITEWAGON's Avatar
Yes. I’ve owned a few of these vehicles. With the Audi Q5 TDI I had to use VCDS to refill the filter, but it wasn’t a drop in filter.
I'm not arguing with you. I really don't know. But I think I was following these instructions which stated: Unlike earlier TDI, your fuel tank's electric lift pump does not cycle on when you turn the key to "ON". And they show the procedure to use VCDS.
https://www.myturbodiesel.com/wiki/f...d-audi-a3-tdi/
By the way, OP that site has lots of great DIY tutorials for general maintenance. Its a great reference.
Old January 3rd, 2019, 06:35   #40
There's a lot of debate about this. I find the procedure with VCDS to be kind of a PITA and I doubt most shops (or the dealer) do it. The pump will run if you cycle the key. I just put in the new filter and fill the canister before putting the top on. I don't think the car is going to blow up.
2002 Jetta wagon, 412K, RC3+; 1993 Mercedes-Benz 300D 2.5, 199K; 1997 Passat, 289K; '99.5 Golf, 262K; 2011 335d, 64K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old January 3rd, 2019, 07:51   #41
KeyTDI
Thanks for the input.
I will refill the canister for sure with something like diesel klean or diesel
Purge.
I think I could maybe pull the rear seat and jumper the pump as it’s so easy to get at.
Service supplies are steadily arriving.
I spent a couple of hours yesterday on some cleaning and repairs. The car is truely filth under the surface. Pulled the rear seats up and it’s ugly under there!
The passthru hatch in the rear seats was not locking. Full
Of sand, grit and dirt. I managed to get it working and latched eventually. Rear seat air vent in the center console is busted. Scrubbed the roof and pillars in the drivers side and after 3 runs the cloth is cleaner.
Tire pressures were low at 28psi all around, so set them at 36.
Did my first good run in the car last night. My home to LAX Airport to pick up our son. About 65 miles each way. One way average at 70-75mph in the car pool netted 47.5mph. After spending 30 miles crawling around the airport and then running back a little harder the display dropped to 43mpg. Still impressive.
Be happier with new oil and filters tho!!!
Old January 3rd, 2019, 08:13   #42
Keep in mind the FE reading in the cluster is probably reading 5-10% high. You can calibrate it with VCDS.
I can't believe how congested the loop around the LAX terminals has gotten. One recent trip there it took me 45 min to get from the rental return to Terminal 4. Insane.
Old January 3rd, 2019, 08:32   #43
KeyTDI
Yes, LAX is a cluster. Adding to the mix last night was 2x FD trucks racing into the mix.
I just use the display as a relative guide. I generally use the brim technique to check absolute.
Our ML 320 Bluetec would have been about 27 mpg on that same run. My 190d would have done about 35 mpg.
Old January 3rd, 2019, 10:55   #44
Matt927
Matt927's Avatar
TDI(s): several
Thought there was a TSB put out by VW concerning priming the fuel filter via the computer after a change. Need to look around for it.
Matt927 is offline   Reply With Quote
Old January 5th, 2019, 19:46   #45
KeyTDI
What is this I found under the seat?
Cup holder thingy?
Been cleaning....
Started at the back...
I think I said this car needed some TLC...
Pulled the rear floor, spare wheel etc...
This is how it looked...
Brown stuff is either Cola, or Coffee... either way it was like concrete...
Mixed a gallon of hot water/soap mix and scrubbed... and scrubbed...
This was up on bulge on the spare wheel well, rear Bumper interface... This is what had fell down from gap in the rear floor or hatch latch...
Anyway, no sign of rear end damage!
2 hours later...
Spare wheel is good, and I put 36 psi in it.
All reassembled!
2012 Sportwagon electronics problem. keyfarms VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 October 24th, 2013 09:26
2012 Jetta Sportwagon oil changes familyman831 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 May 1st, 2012 12:42
Picked up 2012 Sportwagon for the wife grwoolf VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 August 30th, 2011 10:01
Wish this TDI owner a safe journey Herm TDI TDI 101 0 May 30th, 2011 12:50
Soon to be Owner of 2010 TDI Sportwagon MonthOLDpickle VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 20 December 4th, 2009 14:43
© 1996 - 2020, All Rights Reserved
Page generated in 0.16963 seconds with 11 queries
[Output: 132.97 Kb. compressed to 112.30 Kb. by saving 20.67 Kb. (15.55%)]
