Old November 11th, 2019, 07:32   #331
KeyTDI
Quick update:
Did the rear brakes.
The Harbor Freight brake caliper piston kit worked great and was $35 out the door with the 20% off coupon.
The Zimmerman Rotors and Akebono pads bedded in after 20 miles and feel fine.
Changed the oil again 4400 miles yesterday, as I thought I was driving it to Az today, and will be loaded up with 4 adults and luggage.....
Noticed evidence of a slight oil leak which I photographed, for investigation, but the oil change went smoothly. Tiny bit of fuzz on the drain plug magnet, but fine. Oil will go out to Blackstone for analysis.
However, I suddenly noticed that the inside shoulder of the front tires is wearing badly, and Iím not comfortable with them. There is no tread left for the inner inch or so, but no threads showing yet.
I will leave the VW at home and take our Mercedes ML Bluetec instead.
Will post pics later.
Anyone have experience with inner tire wear on these VWs, and is it normally just alignment or should I check for wear anywhere?
KeyTDI is offline   Reply With Quote
Old November 11th, 2019, 08:08   #332
prsa01
Originally Posted by KeyTDI View Post
Quick update:
However, I suddenly noticed that the inside shoulder of the front tires is wearing badly, and I’m not comfortable with them. There is no tread left for the inner inch or so, but no threads showing yet.
My earlier gen vws did seem to wear the tire insides more than outsides, at least in the front. Haven't noticed on this one yet. Don't have a solution for you. Someone will know if that points to toe-in or whatever.
14 JSW 6mt pano & backup cam
96 B4v eCodes
prsa01 is offline   Reply With Quote
Old November 13th, 2019, 13:46   #333
Rockeye
Fuel Economy: 50mpg 95% Highway driving.
The insides of my tires wore down way faster. I actually didn't notice how bad they were worn until I changed out my front brakes. Pulled the first tire off and not only could see the obvious wear (something the VA state inspection should have caught before the vehicle was sold) but the major cupping. You didn't even have to run your hands across the contact patch it was that bad. 4 new Falken Pro G5 Sports later and the car drives way better than I could have imagined.
The Tec at the tire shop noted that German cars tend to have a little more negative camber to help provide a "sportier" ride. Its believable, but I tend to take the advice of people selling me something with a grain of salt.
Rockeye is offline   Reply With Quote
Old November 13th, 2019, 15:37   #334
Geordi
Geordi's Avatar
Location: Somewhere between Heaven and Hell. But it is really hot here in S. Florida...
The tire tech at your shop wasn't wrong - I had one show me that the control arms on my 03 TDI that should have had slots to adjust the camber... Were ROUND and that the camber was basically locked in from the factory. He said that there wasn't really anything he could do, that he could adjust the toe and align the tires that way, but if they started cupping that rotation was really the only cure for most German cars.
That car never really got severe with the cupping, but I had two other TDIs that did. I'm not normally that religious about the tire rotation on my other cars, but I had to be on those two.
I always knew beans would give me gas. But I never expected Diesel!
Geordi is offline   Reply With Quote
Old November 13th, 2019, 18:30   #335
Rockeye
I drive about 3500 miles a month. Guess im gonna have to get religious about the tire changes. Thankfully that tire shop does free tire balances and rotations as long as I have the car.
Old November 15th, 2019, 16:48   #336
KeyTDI
Ok, will report back on what I find.
Silly question...
My Son has a 2016 Audi Allroad, with 20k miles on it... and he put Porsche front brakes on recently...
So he has some good rotors/calipers/pads from his car up for grabs... and I will be needing rotors and pads soooo.... was wondering if they would fit my VW...???
Old November 16th, 2019, 19:50   #337
Geordi
Geordi's Avatar
Maybe. Only way to cross something like that is to have a good look at the actual parts.
Old November 20th, 2019, 16:23   #338
KeyTDI
Looked and found his calipers are large single piston and mine look like twin pistons. Then measured the stock rotors at 312mm, his are 320mm.
Not gonna happen.
Ok, so my VW started to do something odd this week.
Stopped locking and unlocking from the key remote. Also when I open the door, it’s chiming at me, but no info about why from the MFI.
Anyone have any knowledge?
Old November 20th, 2019, 17:11   #339
bizzle
bizzle's Avatar
Change the battery if it's not new and see if that resolves the issue.
bizzle is offline   Reply With Quote
Old November 21st, 2019, 07:19   #340
crashtested
crashtested's Avatar
Not gonna happen.
Stopped locking and unlocking from the key remote. Also when I open the door, itís chiming at me, but no info about why from the MFI.
Had something similar on our old 2010 and it was one of the rear door lock modules that had to be replaced. The "Lock" indicator for that door would not light up nor would it lock even though the alarm would be set.
'14 GSW
crashtested is offline   Reply With Quote
Old November 29th, 2019, 11:02   #341
KeyTDI
Update:
Changed the Key battery and it seems to have cured it!
Old December 14th, 2019, 14:41   #342
KeyTDI
Confirming that the key Battery must have been the issue, as it has not happened since...
Blackstone report came in, looks good, but not perfect.
Will post the whole thing for reference, but here is the lab's comments..
Your engine looks pretty good in this second report. Aluminum and chrome are fine next to averages so we aren't seeing as much piston or ring wear, but iron is actually higher on a per-mile basis, showing more steel wear than last time.
It may look lower at face value, but iron should be a little lower since averages are based on about 8,800 miles. We'll just watch it from here. The viscosity was a little low
and there was some fuel (1.0%), but neither is problematic at these levels. Small amounts of fuel are often
from normal use. Feel free to use this oil if you like it.
Old December 14th, 2019, 20:34   #343
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
That would be great if you could post a picture of your levels to compare. I just got my kit to sent.
JELLOWSUBMARINE is offline   Reply With Quote
Old December 15th, 2019, 08:26   #344
KeyTDI
Will do today if I get a minute.
Old December 15th, 2019, 11:19   #345
KeyTDI
Have the PDF file ready, but cant seem to attach or insert it anywhere...
My posting rules say I cant add attachments... why?
2012 Sportwagon electronics problem. keyfarms VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 October 24th, 2013 09:26
2012 Jetta Sportwagon oil changes familyman831 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 May 1st, 2012 12:42
Picked up 2012 Sportwagon for the wife grwoolf VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 August 30th, 2011 10:01
Wish this TDI owner a safe journey Herm TDI TDI 101 0 May 30th, 2011 12:50
Soon to be Owner of 2010 TDI Sportwagon MonthOLDpickle VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 20 December 4th, 2009 14:43
© 1996 - 2020, All Rights Reserved
Page generated in 0.17598 seconds with 11 queries
[Output: 127.78 Kb. compressed to 107.23 Kb. by saving 20.55 Kb. (16.08%)]
