Old December 1st, 2018, 12:07   #1
alireza57
TDI(s): touran
Default Camshaft replacement
Can any1 advice
Is there anyway I can replace the camshaft on vw golf mk5 1.9 tdi without removing tandom pump, and do I have to replace the cambelt as well as it replace on 40k mile ago
Is there any good write up and advice for camshaft repair in here some1 can give me a link please
Appreciate it
Sent from my CLT-L09 using Tapatalk
alireza57 is offline   Reply With Quote
Old December 1st, 2018, 13:58   #2
81-1.6
Don't try it without removing the tandem pump. It's not that hard, make sure you have a new tandem pump gasket and all new bolts for the bearing caps.
81-1.6 is offline   Reply With Quote
Old December 2nd, 2018, 10:45   #3
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
Default It can be done
Originally Posted by alireza57 View Post
Can any1 advice
Appreciate it
Replacing the camshaft without removing the tandem pump can be done, as that is the way I did it with mine. Search this forum for posts by Frank06 and others for a great deal of useful information about cams.
Briefly, what you have to do is first position the engine at TDC, remove the belt, rotate the crankshaft backwards 90 degrees to keep all the pistons out of the way of the valves, then rotate the camshaft 90 degrees clockwise so the tandem pump slot is oriented vertically and there is minimal valve spring upward force on the #4 cylinder. This will mean that both #1 cylinder cam lobes point to the front of the car. The camshaft can be both removed and installed safely without damaging anything if it is in this position.
I think they whole procedure is on the board here in a post somewhere, but I cannot locate it right now. I have the complete, detailed instructions from Franko6 because I bought all the parts for the job from him, but as it is his written work and not mine, I do not feel at liberty to post them.
sptsailing is offline   Reply With Quote
Old December 3rd, 2018, 09:47   #4
alireza57
TDI(s): touran
Hi thank u does this work for any 1.9tdi engine?
Old December 3rd, 2018, 10:42   #5
sptsailing
sptsailing's Avatar
Mine is a BRM engine. I think it might be the same for a BEW, but I really have no idea. I am not a professional mechanic. I just studied my BRM Jetta enough to do the work myself, and can report from first hand experience on only that.
Old December 5th, 2018, 10:23   #6
Carlos_TJ
I did mine without removing the TP
- set the engine to TDC using crank index tool
- moved crank counterclockwise 90 deg so all pistons are in the middle of their strokes.
- removed belt
- spun camshaft until "slot" joining it to the TP was vertical (no piston impact because all pistons are mid way in the cylinders right?)
- removed all fastners holding cam
- cam should be free by pulling from the top
Install is pretty much reverse of the steps.
Carlos_TJ is offline   Reply With Quote
Old December 5th, 2018, 10:47   #7
invader
invader's Avatar
Can any1 advice
Appreciate it
I have the Cam tools and timing belt tools that I will give you a good deal on if you need them. I don't have my car anymore so I don't need them.
2006 Jetta TDI Black DSG Auto, KermaTDI Super19 Turbo-w-Kerma/Alligator tune, Boost Logic cold air intake and 3" exhaust, Deval body kit, Eurogear front grille, rear lip spoiler, Euro LED tail lights, Helix smoked angle eye projector head lights, fog lamp kit, Amsoil bypass filter kit, Newsouth gauges, smoked front side markers, Koni coilovers, BSH rear sway bar, ASA AR9 19x8.5 rims
http://good-times.webshots.com/album/563402656rDTSjp
1997 Ford F250 Powerstroke diesel heavily modified
invader is offline   Reply With Quote
Old December 5th, 2018, 13:47   #8
vwztips
vwztips's Avatar
BEW, BRM and BHW are all the same. Personally, I would remove the tandem pump to 1. make the job easier and 2. the TP gaskets are probe to leak and in turn take out the temp sensor housing. Also, I would replace the timing belt and water pump while in there. It's not a lot of money for the parts and you basically get to reset everything to 0 at the same time.
Also, if it is a BRM, and you are tempted to go with the cheaper BEW cam, just know that there will be a noticeable power drop from the BRM to the BEW cam
vwztips is offline   Reply With Quote
Old December 6th, 2018, 01:52   #9
alireza57
TDI(s): touran
I going to replace cambelt and waterpump along camshaft the question is do I have to do the camshaft first then put new belt or do the belt fist then then camshaft or it doesn't matter
Old December 6th, 2018, 02:08   #10
alireza57
TDI(s): touran
- removed belt
Correct me if I am wrong
Place the crank on Tdc lock it
Take the belt off then
Remove the crank lock
Then turn the crank counterclockwise quarter turn... While the belts off
Or set the crank and camshaft into Tdc then turn the crank quarter turn counterclockwise so the position of the crank and camshaft not Tdc any more
In that position remove the belt and everything else then fit the camshaft in the same position as it was on removal and fit everything back...
Can I do the injector adjustment by turning the camshaft clockwise and anticlockwise while the belt not fitted and crank is not in Tdc?
Or I have to refit the belt first then make sure of Tdc position then adjust the injector by turning the crank?
Old December 6th, 2018, 02:51   #11
Tdijarhead
Here is a link for cam replacement over at myturbodiesel, complete with videos.
https://www.myturbodiesel.com/wiki/c...tdi-pd-engine/
Replace the cambelt otherwise you’ll be back in 40k miles doing a belt job, and you already have the engine apart.
I would remove the tandem pump. On a BEW engine there are 3 13mm bolts holding it on. I replaced mine without removing the pump and it only increases the complication factor, and I had a leaking pump gasket afterwords so after I had the job completely done I still had to remove the pump and replace the gasket.
For the $10 or so it’s worth it to become a premium member at myturbodiesel so you can see the second part of the write up.
Tdijarhead is offline   Reply With Quote
Old December 6th, 2018, 06:45   #12
Carlos_TJ
It should not make a difference, because the belt removal process its just a matter of loosening the tensioner and pulling the belt. There should be no need to spin the crank.
Positioning the crank 90 deg ccw allows you to spin the cam at your convenience such as when setting inj lash.
I also recommend replacing t-belt and associated hardware while there.
As for the remove/do not remove the tp, if you go for not removing it, make sure the gasket is not leaking oil into the driver side of the engine. Otherway its a good timw to replace it.
If its your first time replacing the cam, grab an extra cam seal. They are easy to damage when inserting in the cam snout.
Please observe the general guidelines
* if tbelt is mounted and torqued and need to spin the cam/crank ALWAYS spin BY THE CRANK.
* once the belt is removed and the pistons parked midway (by the 90 deg ccw) you can spin the cam by its hub.
* please observe all torque sequences and specs for the different fasteners.
The myturbodiesel videls are golden and i also recommend paying the full membership. They are worth gold for the non professional mechanic.
Old December 6th, 2018, 08:22   #13
alireza57
TDI(s): touran
Replace the cambelt otherwise youíll be back in 40k miles doing a belt job, and you already have the engine apart.
For the $10 or so itís worth it to become a premium member at myturbodiesel so you can see the second part of the write up.
Thanks my engine is bxe... Do they are different as it looks the same the1 in video? Another question while belts off and turn the crank quarter turn ccw to do injector adjustment by turning the cam with hub.. Does tandom pump have to fitted b4 adjustment or can fitted after the adjust the injector?
Old December 6th, 2018, 08:27   #14
alireza57
TDI(s): touran
thank u for info
Old December 6th, 2018, 08:57   #15
Tdijarhead
The tandem pump is not in time with anything on the engine. So it can be done afterward. BXE,BEW, BRM I think are all similar so it shouldn't make a difference. I saw you were from the UK so I was wondering what engine you might have.
However I have never seen a BXE engine so maybe someone with more knowledge will chime in on that part of your question.
Camshaft replacement for brm Dbg10 TDI 101 15 June 23rd, 2018 10:05
Camshaft Replacement Volunteer TDI 101 0 May 18th, 2018 17:01
Camshaft Replacement kpaske West Coast Canada/USA 3 March 16th, 2015 19:14
Camshaft replacement help girvil VW MKV-A5 Golf/Jettas 3 June 17th, 2010 07:54
Camshaft replacement info studebaker VW MKV-A5 Golf/Jettas 4 October 2nd, 2009 11:13
© 1996 - 2020, All Rights Reserved
Page generated in 0.17387 seconds with 11 queries
[Output: 134.99 Kb. compressed to 114.13 Kb. by saving 20.86 Kb. (15.45%)]
