Old June 7th, 2010, 18:18   #1
TDI-AHOLIC
Default recirculating air/ fresh air is constant
My 06 jetta has fresh air coming into the cab no matter if the recirc air button is on or off, Is the flap stuck or is there a fuse possibly blown? If you have run into this problem let me know, Thanks
TDI-AHOLIC is offline   Reply With Quote
Old June 7th, 2010, 20:23   #2
ZiggyTheHamster
ZiggyTheHamster's Avatar
I realize that not all cars are the same, but try activating each position with recirc off and then try with it on. I had a stuck flap/cable/something at one point (I got in the dash and got it stuck, oops), and I fixed it by trying every position until it moved smoothly. My problem was that I couldn't move it to defrost.
2009 VW Jetta TDI - Black w/ DSG Born: 5/2009
DSG Paddle Shift Steering Wheel
RCD-510 Stereo
9W2 Bluetooth
ZiggyTheHamster is offline   Reply With Quote
Old June 7th, 2010, 21:51   #3
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
With it in the 'OFF' setting there will be No airflow.
Even with the recric, it still takes in a small percentage of outside air..
2018 F150 3.5 ECO 3.55 10spd 20s 2tone 26mpg 2turb
2006.5 DE DSG, RC2, Sunroof, 200K miles, 61MPG best
2005.5 Jetta-5 SP LSD Spec S2 130K ELF506 10-30W OCI=20k ORIGINAL CAM RSB Diesel custom 2.5DP/3" SS Pkg 1 Auto-dim mirror auto-WW auto-climate 248tq=150HP RC2 lowered 312 brakes
Mach1 is offline   Reply With Quote
Old June 8th, 2010, 20:24   #4
TDI-AHOLIC
ziggy when I turn the knob to defrost it made a noise like a small air compressor running then it stopped. there is still air coming through but it might be less ill try it tonight in each position with the recirc button on and off, thanks and to mach 1 there is air flow when the the blower fan is in the off position
Old June 9th, 2010, 06:32   #5
ZiggyTheHamster
Not knowing how the HVAC system is set up, it sounds like something is just caught. Just move to each position and leave it there for 5-10 seconds and continue on to the next, then do the same thing with recirculate on. If that fails, you might have a leak or a broken flap somewhere. Look under the glove box for anything that might look broken (like, get on your back and look up) - the Jetta might not have anything to look at (remove the plastic part, maybe?), but my Altima definitely had a cable that was actuated by the temp lever and if something is caught in the cable (like an RCA cable), it doesn't work right.
HTH.
RCD-510 Stereo
9W2 Bluetooth
Old June 9th, 2010, 06:40   #6
D-Cell_Mekanick
Fuel Economy: 45ish
I always have some flow with the fan switch in off. I only notice it tho when I have the air flow going to the vents facing you.
2014 Passat SEL TDI(GONE BUT NOT FORGOTTEN). Tungsten Silver exterior with Titan Black interior. I have VCDS HEX-USB+CAN, still learning how to use it.
D-Cell_Mekanick is offline   Reply With Quote
Old June 9th, 2010, 07:02   #7
tdiatlast
Originally Posted by TDI-AHOLIC
... there is air flow when the the blower fan is in the off position...
While the car is in motion, or sitting still?
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old June 9th, 2010, 07:40   #8
D-Cell_Mekanick
Fuel Economy: 45ish
MIne is only with car in motion.
Old June 10th, 2010, 17:46   #9
TDI-AHOLIC
when the car is in motion
Old June 14th, 2010, 19:58   #10
TDICube
I had a problem with the electrical motor that moves the flapper and directs air flow. My problem started with a vibration directly behind the passenger side glovebox when the car was initially started. After taking off the glovebox (previous pictoral write-up helped me), the motor and flapper will be directly in front of you. The flapper is located right of center. A green rubber gasket covers the flapper sides.
With the glovebox removed, cycle the recirc button. If the motor is working correctly, the flapper will open and close. If the flapper motor is faulty, you will need to unbolt a power panel mounted directly in front of the electrical motor. The motor is mounted by a snap connection and is fairly easy to remove and replace.
TDI cube
TDICube is offline   Reply With Quote
Old June 16th, 2010, 16:52   #11
TDI-AHOLIC
do you have a link to that previous write up
Old June 16th, 2010, 19:31   #12
TDICube
Default link to step by step glovebox
This link will get you to the removal procedure.
http://furmanka.blogspot.com/2007/12...omowaniem.html
The electric motor is way-easy to replace after removing the electrical power panel from it's mounts. Be careful to mount the motor/gears in the correct position (recirc or outside air) prior to installation.
TDI Cube
Page generated in 0.12593 seconds with 10 queries
[Output: 101.69 Kb. compressed to 84.68 Kb. by saving 17.00 Kb. (16.72%)]
