Old December 12th, 2018, 11:04   #31
alireza57
TDI(s): touran
Originally Posted by Vince Waldon View Post
Not much VCDS can reliably tell you until you get the engine running, and I'm personally not sure disconnecting the injector harness helps much here... you want to know if it's firing.
Can you hear the in-tank fuel pump running for 5-10 seconds when you first turn the key to ON (may have to lift the back seat to hear it well)?
It's not uncommon for the in-tank pump to fail; the car will still run fine...for years...until the tandem pump loses prime for some reason.
My car is 1.9tdi touran 2009 7seater isit going to be under 2 rear seat or I best to look at service manual
Sent from my CLT-L09 using Tapatalk
alireza57 is offline   Reply With Quote
Old December 12th, 2018, 11:10   #32
alireza57
TDI(s): touran
I just been and when I turn the key 1 turn I can hear the noise from the rear for like 2 second so I think the fuel pump in tank does works
Old December 13th, 2018, 23:45   #33
alireza57
TDI(s): touran
Hello mate
Managed to start the car as good as b4
I want to apply some treadlock on tensioner bolt isit possible to do it by undo the bolt and apply or it going to loose its tension and need to be time again will this possible without remove the engine mount?
Camshaft replacement for brm Dbg10 TDI 101 15 June 23rd, 2018 10:05
Camshaft Replacement Volunteer TDI 101 0 May 18th, 2018 17:01
Camshaft Replacement kpaske West Coast Canada/USA 3 March 16th, 2015 19:14
Camshaft replacement help girvil VW MKV-A5 Golf/Jettas 3 June 17th, 2010 07:54
Camshaft replacement info studebaker VW MKV-A5 Golf/Jettas 4 October 2nd, 2009 11:13
Page generated in 0.12569 seconds with 13 queries
[Output: 61.16 Kb. compressed to 55.87 Kb. by saving 5.28 Kb. (8.64%)]
