Old August 18th, 2019, 06:37   #1
Jake Brake
Jake Brake's Avatar
Default Hard to find exhaust leak
I am pretty certain i have an exhaust leak because no puff of black smoke. I have a pretty loud hiss when building boost.
What i have done
1: bypassed egr cooler
2: replaced flexible exhaust piece by cat.
3: cleaned and looked all over for soot tracks
It only leaks under moderate to high boost and does zap some power.
Working on making a homade smoker system with an old soldering iron, paint can and acouple of fittings and baby oil with an old sock for a wick.
My question is how prone to cracks are the exhaust manifolds?
How prone to blowing out exhaust manifold
gaskets?
How big of a pain is the manifold to remove?
Found out if egr and cooler is off you can remove down pipe with cat out of the top. It has to be jacked up pretty high to do so.
Jake Brake is offline   Reply With Quote
Old August 21st, 2019, 09:32   #2
imo000
imo000's Avatar
Fuel Economy: Good enough
Are you sure it isn't a boost leak in the intake system?
imo000 is offline   Reply With Quote
Old August 21st, 2019, 09:34   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Never seen an exhaust leak on any BHW car ever.
Seen plenty of charge air leaks, though.
oilhammer
www.cardocautomotive.com
Old August 21st, 2019, 13:45   #4
Jake Brake
Jake Brake's Avatar
It might be, no smoke though. I have taken off the front bumper cover and checked each connection of my front mount intercooler too. My flex piece on the exhaust was definitely bad.
I will finish my smoker and try it on the intercooler side. Got 2 young grandkids to look after, daughter had major back surgery and not a lot of time to tinker right now.
Old August 21st, 2019, 13:54   #5
Jake Brake
Jake Brake's Avatar
Have a beaded lip on all my intercooler pipes and T clamps. I cleaned all connections and used hair spray to make the pipes stay put better.
Hair spray works pretty good on a grease free pipe and coupler hose. I sanded the polished area of the aluminum pipes that are clamped as well.
Old August 22nd, 2019, 18:53   #6
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Come to Canada We live in the "salt" belt, just about every BHW needs a mid-muffler here!
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old August 23rd, 2019, 03:44   #7
oilhammer
oilhammer's Avatar
I bet. I see some stuff periodically from the salt belt. It is awful, no idea how you guys deal with that.
oilhammer
Old August 23rd, 2019, 07:39   #8
Scubanero
Scubanero's Avatar
He meant eastern Canada.
There are 10 kinds of people in the world: those that understand binary and those that don't.
Scubanero is offline   Reply With Quote
Old August 23rd, 2019, 09:37   #9
Jake Brake
Jake Brake's Avatar
Thanks guys, I'll post back when i find my leak.
Old August 23rd, 2019, 09:50   #10
imo000
imo000's Avatar
It's simple, we have to buy cars more often. The VWs have excellent corrosion protection and last a long time. Mazdas on the other hand, if you are quiet, you can hear them rust!
Old August 23rd, 2019, 19:51   #11
Uberhare
Uberhare's Avatar
TDI(s): Too many.
In fact my BHW had a new mid muffler just before I took it off the road (car was rotten) if anyone needs one!
Old August 29th, 2019, 17:52   #12
Jake Brake
Jake Brake's Avatar
I finished my smoker and tapped into the intercooler side. It was coming from the intercooler. The smoker works brilliantly! Used a friends old nebulizer pump to push the smoke.
Old August 30th, 2019, 03:23   #13
oilhammer
oilhammer's Avatar
Do NOT try an eBay intercooler. Just get an OEM (Modine) one. Trust me on that.
oilhammer
Old August 30th, 2019, 17:09   #14
Jake Brake
Jake Brake's Avatar
I was already running a front mount intercooler. I have pitched many of the original hoses.
The intercooler is a bar and link type.
Looked around my garage and found most of what I need to hook up the stock intercooler.
May go ahead and hook it back up. I have get a new hose for the one off the turbo.
Old September 3rd, 2019, 06:21   #15
imo000
imo000's Avatar
That's the expensive hose.
Strange noise detected. Similar to exhaust leak, but isn't an exh. leak. Jesse_Boyer VW MKIV-A4 TDIs (VE and PD) 13 January 28th, 2014 10:39
Upgraded turbo; have exhaust leak that I can't find hpc TDI Power Enhancements 16 March 6th, 2013 19:00
Adding UV leak detector dye to oil to find leak srponies TDI 101 16 July 4th, 2012 04:18
Would you call a Leak in EGR piping an exhaust leak? Toolz VW MKIV-A4 TDIs (VE and PD) 4 February 9th, 2010 11:07
hard to find? elindsay TDI Cars for Sale/Wanted 4 September 11th, 2003 10:08
Page generated in 0.18426 seconds with 11 queries
[Output: 128.85 Kb. compressed to 106.70 Kb. by saving 22.16 Kb. (17.20%)]
