Old August 14th, 2019, 09:42   #1
Huelsdonk
Default Calling electrical engineering TDI gods
I have two EDC16u34 ecus with suspected bad g28 crankshaft position sensor circuits. The first ecu failed while installed in the original car, a 2006 jetta tdi. I was not the owner of the car when it failed, I just chased the problem around for a year. The second ecu was functional for appx 2 weeks and yesterday the engine gave a couple hesitations within a few minutes while driving, then the next time i went to start it took extended cranking times and vcds gives a g28 no signal code. both ecus have been immobilizer deleted as the engine is in a toyota pickup now.
I would like to send my ecu to a guru who knows how to test the circuits and tell me what has happened and why it has happened twice. I would like to talk on the phone to someone and work through my problems. This is beyond frustrating. I have also reflashed both ecus several times with several different sets of code with no positive results. Anyone who is interested please PM me a phone number or i will send mine.
Huelsdonk is offline   Reply With Quote
Old August 26th, 2019, 13:43   #2
mextdi
Talk to Ian at Reflect Tuning. He is the most knowledgeable ECU person I know.
mextdi is offline   Reply With Quote
Calling electrical GURUs whitedog General Automotive 38 October 16th, 2014 15:16
Electrical demon! Calling all gurus please! thatguywiththeTDI TDI 101 18 February 8th, 2013 09:36
Tdi Gods Help!!!! Monkey1 TDI 101 16 April 12th, 2006 22:04
begging help from the TDI gods (or you ;) ) billmn VW MKIV-A4 TDIs (VE and PD) 15 January 20th, 2005 05:29
Calling ETKA Gods!!! TurnpikeMan General VW Discussion 6 December 17th, 2002 14:24
Page generated in 0.15589 seconds with 11 queries
[Output: 51.98 Kb. compressed to 48.09 Kb. by saving 3.89 Kb. (7.48%)]
