Old August 12th, 2019, 14:55   #1
AWD-TDI
Default Clutch needed for 200-250hp daily driven ALH TDI
I just acquired this little gem in the rough and I need to put a GREAT clutch in there that will last and hopefully not slap around like the current unit.
This has the 225hp audi tt 6MT and AWD. What clutch should I be looking for? Audi TT clutch? TDI clutch? Some combo of the two? Are the trans input splines the same on the tt trans as the stocker?
If anyone has some specific recommendations I would very much appreciate it. Looking for the best possible option. I strongly favor an option that simulates the DMF and operates quietly.
What about the flywheel? I know single mass is a must. I believe the unit in there now is very lightweight which kind of sucks for low RPM take off performance but I can deal with that as long as the other performance gains are worth while.
Thoughts ? Opinions? Ridicule ?
Ps the old owner says he has a 500ft lb capable clutch in there that lasted about 50k. Maybe it's a fine choice and was just abused... currently the clutch slips in the power band and is not long for this world.
Anyone have experience with the south bend 425+ ft lbs endurance clutch or the DKM twin disc?
DKM is super nice and maybe the only clutch that will handle the abuse and also not rattle... Not sure of the rattling tho. Will it rattle with a single mass flywheel?
AWD-TDI is offline   Reply With Quote
Old August 12th, 2019, 16:42   #2
Mongler98
South Bend clutch, Enduro stage 2 with a lighter 14lbs flywheel. winner combo. was putting 230 down to that baby with no issues.
Old August 12th, 2019, 16:50   #3
Yourbuddysatin
Fuel Economy: 32-35mpg
Call or email southbend and see what clutch they would recommend.
Yourbuddysatin is offline   Reply With Quote
Old August 13th, 2019, 07:51   #4
AWD-TDI
Did it rattle at idle? I sure would like to get rid of that annoyance.
Sent from my SM-G973W using Tapatalk
Old August 13th, 2019, 07:52   #5
AWD-TDI
I emailed them weeks ago no response. They may not know what to recommend since it's got the audi tt 6MT on it? I will follow up.
Old August 13th, 2019, 09:42   #6
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Idparts.com carries those kits in stock.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old August 13th, 2019, 11:54   #7
Yourbuddysatin
Hmmm maybe call then. I would think by now someone had done something along these same lines as your set up. If not then maybe a custom set up. I have used southbend for everything diesel and not one problem from them.
Old August 13th, 2019, 15:13   #8
AWD-TDI
Wellllll turns out they did email me back and I missed it. So am going back and forth now. Will advise what comes from it. Hoping to avoid having to take car apart to figure out what clutch it needs before ordering new one. Down time is a pain. To complicate things the internal gears were swapped with a newer tdi 6mt set for better highway rpm. No clue what is actually in the case or spline count etc. I'd be real surprised anyone could tell me with confidence what will work but still hoping. Maybe all spline counts are the same across all possible options?
Joy of custom car building
Old August 13th, 2019, 16:02   #9
Yourbuddysatin
It’s either a 2.5 trans or 2.0 trans from a mk6 that has super long gears for being gas. I’m 99% it’s a 2.0 gear box. The 5ft gear is longer than 6th on a tdi trans. I’m just not so sure about swapping gears from a newer gear box into an older Audi trans.
Old August 14th, 2019, 16:25   #10
AWD-TDI
South bend got back to me saying I need the 1.8T audi clutch with 23 splines. Call me superstitious but I plan to take it apart and then order parts. Not getting warm fuzzy feelings that this is a certainty and dont want to mess with returning a clutch across a border. I'll post back when I get it sorted.
Cheers
Old August 17th, 2019, 00:21   #11
adamss24
Fuel Economy: 35-45mpg
Its best to do that, you dont want to find out that your new clutch isnt anything like the one you've just removed ! I would suggest a sachs SRE organic clutch plate and stronger pressure plate- stock like OEM feel with just a litle more pedal pressure...You will need to measure your clutch/flywheel stack to see what it works from their lineup !
adamss24 is offline   Reply With Quote
ALH parts. 11mm pump and stg2 daily clutch Kraiger Private TDI Items for Sale/Wanted 10 November 9th, 2014 12:53
Looking for advice: 250HP/400lbs from a ALH, is this what I need? Dorkage TDI Power Enhancements 61 January 28th, 2014 14:50
MK1 rabbit + ALH > Daily Driven Swap TDINIT TDI Conversions 22 December 19th, 2012 12:49
17/22 Daily Driven? TOPH R Ontario 12 October 21st, 2012 10:41
200 Miles driven after half tank corn27 TDI Fuel Economy 29 January 16th, 2003 06:41
Page generated in 0.16751 seconds with 11 queries
[Output: 101.62 Kb. compressed to 86.45 Kb. by saving 15.17 Kb. (14.93%)]
