Old August 12th, 2019, 11:20   #1
smity71
Default 06 BRM PD Bad Camshaft or bad Injector seals? Or What???
I took the intake pipe off just after the MAF and did not have any air puffing back towards the MAF. I then took the oil fill cap off and it felt like it the exhaust coming from the tail pipe. It was blowing out at a good flow. Any ideas for this sympton? Please and thank you for any help.
smity71 is offline   Reply With Quote
Old August 12th, 2019, 12:23   #2
kdawg89
Thats all normal, what problem are you trying to solve?
15 Golf TDI SEL DSG, Kerma TDI Tunes
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old August 12th, 2019, 17:12   #3
smity71
When I say it was flowing out it is not normal at the amount of air flow. It started to stumble when driving off and runs rough. I have max injector quantities on all injectors 3.00, -2.99, 3.01, -3.00. I did have a serpentine belt break on it a few months back but I replaced it and didn't have issues with it until recently when it died on the interstate gettiing off at an exit. After that I replaced the fuel filter( it was literally all black) and checked the air filter which was clean. Thinking I should start with injector seals??(maybe leaking exhaust back into the crankcase if that is a possible)? Just need some ideas to get this back on the road. It does have approx 283,000 miles.
Old August 13th, 2019, 07:41   #4
kdawg89
If you just set the oil cap on and start it does the cap blow off or just rattle and bounce around?
Old August 13th, 2019, 09:01   #5
smity71
It blows off like it was shot off.
Old August 13th, 2019, 13:31   #6
JETaah
Fuel Economy: 53 max, 42 min, average 46
Hole in a piston, broken rings,
How about a compression test and leak down test?
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old August 14th, 2019, 06:47   #7
James & Son
TDI(s): 2006 Jetta
I am also curious to see if this will or will not require the first, or most likely the second cam replaced and whether the cause.
James & Son is offline   Reply With Quote
What are Symtoms of Bad Injector Seals fastcar4re VW B5 Passat TDIs 3 August 14th, 2017 11:03
Want: Your Bad Camshaft for BRM Combine17 Ontario 6 July 3rd, 2016 07:44
Want: Your Bad Camshaft for BRM Combine17 Ontario 0 June 13th, 2016 10:11
Looking for a bad '06 BRM turbo... Chris Tobin VW MKV-A5 Golf/Jettas 2 February 7th, 2012 09:05
06 BRM bad compression 2nd cylinder andytdiland VW MKV-A5 Golf/Jettas 8 October 2nd, 2011 12:46
Page generated in 0.14411 seconds with 11 queries
[Output: 77.76 Kb. compressed to 67.33 Kb. by saving 10.42 Kb. (13.40%)]
