Old August 9th, 2019, 01:53   #1
zed7862
Default passat 2.0 tdi CR
Hey guys,
was after some help. I recently had the engine light come on and after a scan it stated code:
P2196 02 sensor signal biased / stuck rich bank 1 sensor 1.
I have since replaced the 02 sensor on bank1, checked all the wiring. run diesel system cleaner through it and the light automatically went off but then returned 50 miles later it just doesn’t go away.
wandering if the turbo actuator may need replacing but not sure if that would cause this issue.
Really stuck here and could do with any help please.
Thank you
zed7862 is offline   Reply With Quote
Old August 9th, 2019, 04:03   #2
zed7862
I have a basic bluetooth obd2 reader which i can use with my phone.
i have noticed when reading sensor data there is 0volt to 02S1
is that normal?
took a couple screenshots whilst driving 20mph. can anybody help interpret?
Old August 9th, 2019, 08:16   #3
mextdi
I was looking at normal sensor readings for an O2 sensor and it seems it reads .1 of a volt so maybe that is why the reading is so low.
After you replaced the sensor, what code is it giving you? The same one?
If you are worried about the turbo actuator, the zip tie fix is usually very easy to do and very easily undone as well, it is something to try. I haven't done the zip tie fix on a 2.0 CR, just on the 1.9 PD so you might have better luck on the MK6 forum here because the 2.0 CR is more common on those cars.
How many miles are on your car?
Cheers!
mextdi is offline   Reply With Quote
Old August 9th, 2019, 09:05   #4
zed7862
Hey Mextdi, I have just checked this against another passat and the readings seem to be just as kine are.
im not sure if it could be the actuator I was asking if that could be a possibility as i am not the most experienced with these cars.
123k on the clock mate.
Old August 10th, 2019, 05:07   #5
zed7862
Here is the dreeze frame data
Freeze frame
Freeze frame DTC P2196
Calculated Engine load value 0%
Engine coolant temperature 85 oc
Intake manifold absolute pressure 98 kPa
Engine RPM 1452 rpm
Vehicle speed 50 km/h
Intake air temperature 26 Oc
MAF air flow rate 22.99 g/sec
Throttle position 83%
Fuel rail press. 46870 kPa
Old August 14th, 2019, 23:10   #6
zed7862
just a thought, could it be a faulty MAF due to the engine load value being 0%?
2015 CR Passat TDI HELP ME OUT !!! 6mt short gears kwiatekch TDI Fuel Economy 4 June 27th, 2019 16:08
CR TDI CKRA Passat Dynos? AARodriguez Corp. TDI Power Enhancements 16 August 24th, 2015 13:02
My new Passat 2.0 TDI 140 cr mickyTDI VW Passat Family (NMS and B7) TDIs (2012+) 37 February 14th, 2015 13:29
Sold my '10 CR TDi, so sell me on a '13 Passat clintg60-16v VW Passat Family (NMS and B7) TDIs (2012+) 5 September 23rd, 2012 10:07
Page generated in 0.13432 seconds with 11 queries
[Output: 72.07 Kb. compressed to 62.93 Kb. by saving 9.14 Kb. (12.69%)]
