Old August 8th, 2019, 07:27   #1
myribitsbroke
Default Radio help
Hello all,
2011 Jetta Sportwagon TDI
I'm chasing a radio problem that isn't helped by the fact that VW doesn't provide a fuse panel diagram.
Stock radio died a few weeks ago. I checked fuses but couldn't trace it to that. Read that this is a known issue for this radio (RD510 I think) so I decided to get an aftermarket.
Installation went without issue but the new radio doesn't work either. The chances that I purchased a faulty radio seem low and I'm beginning to think there's an issue in the car.
The following fuses have been checked based on online resources:
Engine compartment:
F8 and F18 (both were empty)
Dashboard:
42 and 43 (among a bunch of others)
Can anyone confirm what fuse controls the radio on this model?
Sent from my Pixel using Tapatalk
myribitsbroke is offline   Reply With Quote
Old August 18th, 2019, 19:13   #2
Thunder Chicken
Thunder Chicken's Avatar
I recently went through similar issues. I bypassed it all by putting in an add-a fuse on an ignition controlled circuit. I don’t remember which one. It was trial and error. I ran a new wire to the radio’s 12v supply. I was getting an ‘infotainment bus error’ on VCDS..... and a variable voltage on the 12v supply to the radio, causing it to not power on sometimes....
Thunder Chicken is offline   Reply With Quote
'01 Monsoon radio: code needed after power-off? or does the radio recognize the car? verylongdrive VW MKIV-A4 TDIs (VE and PD) 8 January 29th, 2018 15:42
Radio Pinouts - Premium VI Radio (Double-DIN unit) Michael Moore General VW Discussion 2 March 1st, 2017 07:41
Radio Dead (2002 TDi, Jetta) - Radio Removal mrGutWrench VW MKIV-A4 TDIs (VE and PD) 5 February 13th, 2014 16:40
Monsoon radio always turns on with radio station #1 and a preset volume that is loud? 5SP TDI VW MKIV-A4 TDIs (VE and PD) 11 January 27th, 2013 17:36
WTB: Radio knob from 2000 Jetta monsoon radio 1JM035157A dynomite Private TDI Items for Sale/Wanted 3 September 5th, 2006 16:48
Page generated in 0.14791 seconds with 11 queries
[Output: 52.94 Kb. compressed to 48.90 Kb. by saving 4.03 Kb. (7.62%)]
