falk_ben
Looking to piece together kit to do my swap.so far my list is as follows;
Anything I have missed?
Looking for a good link where someone has joined a BKD ecu plug to BMN wiring loom.
Not running egr, inlet flaps, egr cooler, or exhaust pressure valve. I know I'll have to disable the actuator position sensor (running gtb2260 with cr actuator)
Any advise much appreciated as trying to run 300+ hp.
- BKD Bosch 16 ecu immo off
- BKD injector wiring loom
- BKD Bosch ecu plug and wiring
- BKD Bosch injectors with Firad 120%
