Old August 5th, 2019, 14:11   #1
dkiikka
Default passat manual transmission swap...or not?
I have a 04 passat tdi with 250k miles that I bought new. It's now our "second" car that hauls my dogs and 13' Scamp around. The transmission failed suddenly and I am 99.7% sure is toast with 4 error codes and dribbling oil, unknown to me, for 30 miles before I made it home.
It has a geared bsm, on the 3rd camshaft and timing belt, 4th right axle and flooded TCM in the past.......other than that it's comfortable and always driven great. I've done all work since 100k. It's the devil I know.
My dilemma is; is it worth saving by converting it to a manual or scrap it out and buy something else? It's not worth much as is and probably wouldn't be worth much more (to others) if converted to to a manual. But to me...
Dutch Auto has a swap kit with an EEN for a total rough cost of $1800-$1900 to my door. It seems to include everything including a new Valeo clutch set and new outer CV joints. Quality German has an FHN kit for $1500 that has a used clutch-flywheel set no shipping included, so maybe around $2300 to my door with new clutch. Labor is free.
I need to make a presentation to the financial committee on how to regain the function of our second vehicle, either fix or replace. Would I be beating a dead horse with 250k miles by converting the Passat?
Thanks for any thoughts....?
dkiikka is offline   Reply With Quote
Old August 5th, 2019, 14:53   #2
d24tdi
Can you get a replacement vehicle that fits your needs equally well for the same ~$2500 (don't forget the cost of ECU tune for manual swap, and that number takes you at your word that you consider your time to be free) that you would have equal confidence in as you would in this car with the transmission swap completed?
If the answer is no, and you still like driving the car and know the history, might be worth it. I think the way you're thinking about it is the right way (at least it makes sense to me), looking at the cost and value not in terms of its resale value but rather its value to you relative to alternatives. Almost never pencils to do something like this from the perspective of resale value, so anyone considering it on that basis would best forget about it. But if it gets you a practical and reliable vehicle you expect to get good use out of, and you don't mind the work, and the cost is similar to or less than an equivalent replacement, it could be a logical decision, even if by conventional reasoning putting $2500 and significant time into a broken old car with 250,000 miles would be hard to defend.
Put differently, if it's a decision between $2500 to regain use of a car you like and that works for you, versus a greater cost to replace it with something you like less or that doesn't suit your needs as well, then it doesn't matter that you're spending more than the car's value to keep it going and in fact that's probably the right decision. I (and probably most of us still keeping these cars on the road) face this kind of logic often and so far it has worked out this way for me most of the time.
But if any of the above is not the case, or if you and/or your counterpart already were looking for a reason to replace it, might make more sense to move on. Sounds like the car doesn't owe you much either way, fortunately.
d24tdi is offline   Reply With Quote
Old August 5th, 2019, 15:48   #3
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
I'd fix it. There is nothing of the same size and build quality to replace these cars, let alone a TDI.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old August 5th, 2019, 20:53   #4
vwztips
vwztips's Avatar
I vote fix it.
Buying another used car with unknown service history may put you in much deeper financial hole.
At least with the Passat, you know what you have
vwztips is offline   Reply With Quote
Old August 6th, 2019, 06:22   #5
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
I would keep it. Iím at 349k on my body and transmission. The engine has 270k BSM delete and original cam which is fine(not sure why youíve gone through 3 cams). My transmission is starting to act up I think the Torque converter is going out after my recent 3,000 mile road trip. Iím likely going to find a good used Automatic transmission and install a new torque converter I have in my stock of parts.
bbob203 is offline   Reply With Quote
Old August 6th, 2019, 07:52   #6
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
My vote is convert. The wife breifly convinced me to sell my 04. Bought from the 1st owner in perfect well maintained cond. 225k threw a transmission code several times but overall looked and drove like new... Regret...
JELLOWSUBMARINE is offline   Reply With Quote
Old August 6th, 2019, 14:23   #7
tikal
Fuel Economy: 37 MPG (~ 45% city)
The BHW cams have shown more than anecdotally to have premature wear-out. Few companies have provided alternatives that address this design flaw but cost more $$$.
For owners that have never experienced this problem, well it obviously does not exist :-)
tikal is offline   Reply With Quote
Old August 6th, 2019, 17:18   #8
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
Oh yea for sure they wear out but 3! I have a motor in my garage thats at 315,000 the cam is toast which is why Iím making it a hybrid 2.0ALH. Anyhow I was lucky to get a car with only 80,000 on the motor and Iíve run schaeffers or rotella 5w40 exclusively for the last 200,000.
Old August 7th, 2019, 12:50   #9
papasmurf
papasmurf's Avatar
One thing to consider is the clutch. I have researched and read so much on peoples experiences and I myself keep coming back to needing the clutch flywheel package that Whitbread sells. I have a stage 2 malone tune and I also do some towing so I have to get whats best or I will be doing it the right way later. His combo it right under a grand and lets you use the 240mm flywheel with the 5 speed and bhw starter. The next best thing is sending off what you get from Frans to southbend and having them reline it and do their magic.
papasmurf is offline   Reply With Quote
Old August 7th, 2019, 12:56   #10
dkiikka
Thanks all for your replies. I count 5 yeas and 1 thoughtful maybe. The full cost will probably be closer to $2500+, I forgot about the $300 reflash.
bbob203, I've replaced the cam twice, once at 100 and 200k when I did the timing belt replacements. A few of the lobes had most of the chamfer on the lobe edge worn away. The first 100k oil changes were done with questionable oil. I've used Liquimoly ever since, however even at 200k the chamfers were worn again. The PD engine has very narrow lobes that are subject to high contact pressure. I think I read somewhere that the narrow lobes were a design compromise.
My auto trans had 2 oil and filter changes. Before I did the second one at around 245k, I noticed that when cruising in a higher gear that the engine rpms would randomly come up 100 rpm for a few seconds then go back down, without any change in speed. I thought an oil change may help. I may have caused its demise by the recent change but others would say i was lucky enough to get 250k. Replacing it with a "good" used one would be my first choice but they seem to have such a bad reputation that I have not even considered that as an option. And as I mentioned, the TCM has been flooded several times, not due to the sunroof drains but the drain under the battery getting clogged. This problem came to my attention when all of the shifter lights lit up, then noticed all the water on the passenger floor. I then had learned what transmission limp mode is. I now have a reminder on my phone to annually remove the battery and clean the drain out. However, now when I start the car there is a chance that it imediatly goes into limp mode. If I turn it of then start the engine again, all is fine (except for a few error codes it throws). Its never gone into limp when driving. I thought it's just too much to consider a used tiptronic along with a questionable TCM. I think that the manual convert is the way to go if I keep it. Just need to sell this to my wife.
Hopefully we can make a decision in the next week......
Old August 7th, 2019, 18:53   #11
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
I have a pretty complete 5 speed swap I would sell as I’m going to find a good used auto for mine rather do a swap. I will get it all organized it has a whitbread flywheel but will need a pressure plate and disc.
Old August 8th, 2019, 07:35   #12
dkiikka
Bbob203, why did you decide to get a used auto vs proceeding with the manual swap? If I thought I could find a used auto that had life left in it I would go that way. I just don't know how to evaluate one and most are without any warranty. I think my wife may not like the car as a manual at this point even though she wanted one when we bought it in '04. And it would be a lot less of my free labor.
If I move on the manual swap, what parts do you have that you are looking to sell?
Old August 8th, 2019, 08:34   #13
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
The 5 speed swap came out of a car I bought mostly for the engine. I was never set on using it for sure. I would trust an auto with less than 100k on it but definitely would use a new TC... my current is just starting to act up at 350,000. I think these trannys are better that people give them credit for just seems the TC’s are the weaker link. My reasoning for a good used auto is that I drive a lot with other people in the car who may end up having to drive on long trips and they can’t drive a manual especially in city traffic. I would like a 5 speed manual but it will limit my ability to take breaks from driving on long trips.
Old August 9th, 2019, 19:10   #14
tikal
The way I have read here in TDIClub is that there have been some earlier cam batches worse than later ones. Using the right HDEO or 505.01 (5W40) would help but sometimes despite the oil being used you still get early wear-out and by 'early' I mean around 100K rather than lasting you double that or triple.
Old August 13th, 2019, 13:13   #15
dkiikka
I have decided to move on from the Passat. It's been a really tough decision. I was sure I was going to do the conversion.
After watching an old episode of Kung Fu where a lesson was to be wise enough to know when let go of something before that thing possesses you. The Passat immediately came to mind and the path was clear...
I'll post it in the for sale section soon.
Thanks all again for your input.
B5.5 Passat Manual Swap - Are Euro Transmission from 1.9 and 2.0 the Same? drewkeen Upgrades (non TDI Engine related) 0 January 31st, 2019 15:54
B5 Passat TDI manual transmission swap Walt@EverythingEuro VW B5 Passat TDIs 86 October 14th, 2018 07:30
05 Passat GLS w/ Manual Transmission Swap nomorotors TDI Cars for Sale/Wanted 18 May 29th, 2018 08:13
I need manual transmission swap or tips on my manual!!!! russ_tdi1.9 South Eastern USA 2 July 17th, 2012 15:41
ALH 5-Speed Transmission w Peloquin LSD, .681 5th Gear Swap, and Manual Swap Parts riddleyo Private TDI Items for Sale/Wanted 8 March 3rd, 2012 17:59
Page generated in 0.21770 seconds with 11 queries
[Output: 128.94 Kb. compressed to 108.59 Kb. by saving 20.35 Kb. (15.78%)]
