Texas_sky
2006 Jetta TDI
Removing a outer driver side door panel to replace and found out the T25 Torx screw that removes the key cylinder from the outer door panel is stripped and not coming out. Is there any way to get the panel off without breaking the cable that attaches to the door latch actuator or should I try and remove the actuator and pull the steel cable off without breaking it?
