Old August 1st, 2019, 11:09   #1
325_Guy
TDI(s): MkV Jetta
Default Axles- OEM, GKN, or GSP?
310k and it's time for axles. All 4 boots are toast and I figure with the mileage and towing use, it's best to replace the entire axle. I plan on getting another 300k or more out of this car, so no Rock Auto, eBay, Prothe, etc parts will be installed.
I've found three decent options and wanted to ask opinions on them.
OEM VW- $358 at Jim Ellis VW
GKN- $239 at ID Parts
GSP- $89 at ID Parts
I think that $89 is a little too cheap for a part that's usually three times as much. What are some thoughts on the GKNs? Are they worth the $120 off of the OEM part?
Thanks!
325_Guy is offline   Reply With Quote
Old August 1st, 2019, 13:45   #2
relumalutan
relumalutan's Avatar
Raxles has a good reputation around this forum. Nice guy, fast shipping, he rebuilds them and you send him back your damaged ones as core.
relumalutan is offline   Reply With Quote
Old August 1st, 2019, 14:55   #3
325_Guy
TDI(s): MkV Jetta
Thanks! I'll check them out.
Another question, is it out of the ballpark to think that CV joints at 310k are still good? The boots are splitting but the joints themselves make no noise. Would it be realistic to just replace the boots?
2006 BRM Jetta- 310k and counting
Malone Stage 1.5 w/ EGR Delete
OEM HIDs, GLI Front Grille, OEM GTI LED Tails, Bosal Hitch
Current Project- MIB2 w/ Navigation
Old August 2nd, 2019, 09:18   #4
relumalutan
I don't see why the CV joints would not be good if they are not making any noise while turning. I have replaced the inner booth covers myself on my 06 DSG (the ones for manual transmission are different), it's a messy job, but definitely doable. ID parts has the kits (2 different sizes for the boots), I went with the cheaper one, as that was the correct size for my car. Make sure you are buying a new bolt for the axle, and the 6 bolts per axle that are connecting the axle to the DSG. Might as well buy a
https://www.idparts.com/cv-boot-kit-...sg-p-3273.html
https://www.idparts.com/cv-boot-kit-...sg-p-3494.html
Old August 2nd, 2019, 12:12   #5
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
If the boots been split for a while then I would consider the GKNs assemblies..you can go with the boots as relum said, it is a very nasty dirty job and you would have to get ALL the old grease cause its contaminated, and will accelerate the deteriation of the joint. I liked the job as I replaced the wheel bearings and then just slide in a brand new assembly.
You are going to do the wheel bearings eh?
locktite the inner axle bolts and torque to 30ft lbs.
2018 F150 3.5 ECO 3.55 10spd 20s 2tone 26mpg 2turb
2006.5 DE DSG, RC2, Sunroof, 200K miles, 61MPG best
2005.5 Jetta-5 SP LSD Spec S2 130K ELF506 10-30W OCI=20k ORIGINAL CAM RSB Diesel custom 2.5DP/3" SS Pkg 1 Auto-dim mirror auto-WW auto-climate 248tq=150HP RC2 lowered 312 brakes
Mach1 is offline   Reply With Quote
Old August 2nd, 2019, 12:24   #6
325_Guy
TDI(s): MkV Jetta
Bearings isn't a bad idea, actually. One was replaced about 100k ago, the other is original. I figure they've done their time, haha.
The boots themselves are very lightly split and really haven't flung a lot of grease yet. I feel that I caught them early enough to just replace them. After a thorough cleaning, of course.
I actually found the OEM boots from Jim Ellis VW at a very competitive price compared to the kits available. Waiting for an email back from them about what comes with before I go ahead and order them.
Thanks for the feedback from everyone about replacing the boots only. I wanted to do a reality check first before getting my hands dirty with these.
Old August 2nd, 2019, 13:04   #7
Mach1
Seriously consider doing the bearings while you are right there, I am going to do the rest of mine at 190000, this winter/cool down.
You have of course done boots before? There is a way to do them in order. 310000m you got your money worth out of them. I usually don't rebuild them unless its the first one off, that second one is no fun, you can save some good money although I would have consider mileage on the parts as well. That's a lot of mileage on all those parts.
Old August 2nd, 2019, 13:51   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
GKN/Lobro is who makes many (most) of the drive axles for VAG. So they are OEM.
Chaxles are junk. Don't bother. They'll be bad in 6 months... and by bad I mean worse than OEM axles with 150k miles on them.
oilhammer
www.cardocautomotive.com
Old August 3rd, 2019, 18:55   #9
325_Guy
TDI(s): MkV Jetta
Mach1,
Never done boots, but I've done plenty of other things involving attention to detail, cleanliness, and adherence to proper procedures. What's this order you speak of? Curious!
I may just pull these apart and inspect them first and decide from there whether or not to completely replace or not.
Oilhammer,
Thanks for that! Makes me feel a lot better about getting them if I have to. I don't mind saving a couple hundred dollars for OEM parts.
Old August 4th, 2019, 12:24   #10
Texas_sky
Fuel Economy: unknown at the time, waiting for engine swap
Is there any extra labor to change Axles if doing the transmission and suspension at same time?
Texas_sky is offline   Reply With Quote
Old August 5th, 2019, 03:51   #11
oilhammer
oilhammer's Avatar
Well you'd have to define "doing the transmission and suspension". If that involves removal of the axles, then no. If it does not, then yes.
oilhammer
Old August 8th, 2019, 06:23   #12
325_Guy
TDI(s): MkV Jetta
Quick question, do the inner axles have a backing plate or are the joints open when you disconnect them from the transmission flanges? I'm trying to remember from the last time I had the axles off.
Asking so that I have all my ducks in a row when it comes time to start pulling things apart.
new GKN driveshaft looks used? confused.. OEM? bjrperegrine VW MKV-A5 Golf/Jettas 15 December 17th, 2018 20:36
New OEM Axles Vs Raxles Memphis VW MKIV-A4 TDIs (VE and PD) 35 April 9th, 2018 20:00
OE Quality Replacement Axles by GKN In Stock cevans Vendor & GroupBuy items for sale 25 January 28th, 2017 11:22
GKN Axles & Joint explanation frosz TDI 101 1 February 16th, 2014 07:37
oem axles compatibility oregun VW B5 Passat TDIs 12 January 7th, 2014 14:53
Page generated in 0.15119 seconds with 11 queries
[Output: 109.37 Kb. compressed to 92.14 Kb. by saving 17.23 Kb. (15.75%)]
