Old July 28th, 2019, 13:22   #1
axelseaa
Fuel Economy: 39
Default Oil Leak?
I was starting the process of changing some filter this afternoon and noticed some substantial leaks of sorts. Does anyone have any ideas of likely culprits from these pictures?
B5.5 TDI
https://imgur.com/a/cHJhVmv
Thanks!
axelseaa is offline   Reply With Quote
Old July 29th, 2019, 07:55   #2
Scubanero
Scubanero's Avatar
Substantial? I didn’t see anything to worry about.
There are 10 kinds of people in the world: those that understand binary and those that don't.
Scubanero is offline   Reply With Quote
Old August 1st, 2019, 16:09   #3
ajjw0828
I'd just keep an eye on the oil level. Looks like it might be dripping from the EGR valve. But don't think I'd be overly worried based on the photos. Good luck figuring it out!
ajjw0828 is offline   Reply With Quote
Old August 12th, 2019, 16:50   #4
MagnumVW
My BHW leaks WAY more oil than that (like several drips on the driveway each day) and the oil level hardly even moves. I wouldn't be concerned about it.
MagnumVW is offline   Reply With Quote
Oil leak between oil filter housing and oil cooler mikko.rantalainen VW B5 Passat TDIs 7 February 2nd, 2019 10:58
Fuel Leak and Oil Leak Problems charlieruu TDI 101 2 September 20th, 2016 14:32
Oil leak. Coolant leak. Injection pump leak. Chris_TDI_98 VW MKIII-A3/B4 TDIs 3 April 23rd, 2016 11:00
Power Steering leak, and oil leak questions Spiked1Z VW MKIII-A3/B4 TDIs 7 January 30th, 2014 19:55
Adding UV leak detector dye to oil to find leak srponies TDI 101 16 July 4th, 2012 04:18
Page generated in 0.14637 seconds with 11 queries
[Output: 61.52 Kb. compressed to 55.05 Kb. by saving 6.47 Kb. (10.52%)]
