Cindrlla
I apologize if I'm posting in the wrong forum, but I'm new and having a hard time navigating this website. I'm sure this subject has been done to death, but I can't find the info I need, so I'm sorry to clog the forum because I'm an idiot.
I have an 05 Passat wagon, bought used in 2015. Had to replace the oil pump and all that mess in 2016. The car was running well, except every once in a while the a/c would get a little warm, but then it would get cold again and stay that way for a long time. I figured I just needed to have the freon recharged and it was on the list of things to do, but didn't get around to it. Also, about a year ago, after I turned the lights on and off, there's been an intermittent clicking sound coming from the dash. Like a blinker, but that's not it. Unfortunately ever time I tried to show people this clicking sound it wouldn't happen. They laughed, but it was there, clicking intermittently, no pattern, no rhyme or reason and I never could figure out the source.
Then someone backed into one of my headlights and I had to have that fixed. When I got my car back, on a hot day, the a/c didn't work, nor did the blower except on 4. The a/c light will stay on until you turn it to 4, then it goes out. The body shop guy checked and recharged the freon for me and also the cabin air filter (I need a new one). He said the a/c clutch engages until you turn the control to 4. I have to believe him because I couldn't tell what he was pointing out with the engine running and had no idea what he was pointing at. Everything was spinning and belts were in the way. He said he wasn't a mechanic or an a/c guy, but he's trying to help as I'm 800 miles from home and there's no one in the area that I can find who's really familiar with foreign diesels.
I found this forum and searched for a similar problem. People on here have thought it was the 384 relay. Not sure, but at least y'all helped me find its location. I took it out, looked at it, can't tell whether the solders are cracked or not, so I put it back. Another forum on here, for a different model, said blower motor and/or resistor, which may or may not be under the glove box on the passenger side because I can't figure out how to get that cover off. (Do I yank the hard panel out because it's not foam, pry it with a screwdriver, unscrew all the screws I see and remove the glovebox, take the whole dash off? What?) YouTube videos simplify accessing it and, for me, unless you have that Jetta, it's not that simple. (It's not foam there.) Parts store guys insist it's the controls, not the blower, and got irritated when I questioned them. When I asked for prices on the resistor pack they couldn't find it, said it wasn't available, and it was probably integrated in the blower motor and not separate, so I'd have to buy the whole blower motor. Ummmm..... I don't have anyone else in this town to ask or the $$ to be buying/special ordering parts that may or may not be the problem, nor the $$ or time to take this TDI to a VW repair shop 70 miles away. (Same one that fixed the oil pump disaster. They're good and nice, but REALLY expensive.) This car is my only mode of transportation and eventually I get to go home. It'd be nice for the dog if I had a/c. Can y'all help? Thank you!
