Old July 25th, 2019, 09:50   #1
Rockeye
Default Rear Brakes Tools Required?
Hello,
New guy here.
I just picked up a 2012 4 dr Golf. While driving around the rear brakes started dragging. So in my attempt to do the job myself I am stuck at trying to get the caliper bracket off. What kind of German witchcraft is required to pull off the long bolt holding the caliper bracket off?
Rockeye is offline   Reply With Quote
Old July 25th, 2019, 10:10   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Not sure what you mean. You cannot get it loose? You do not have the proper tool? It will not slide out?
Should be a fairly straightforward rear brake job, lots of cars are set up the same way. Although you may find that the pads and perches just need to be cleaned up and lubed, if the car had been sitting. Brakes last a very long time on these.
oilhammer
www.cardocautomotive.com
Old July 25th, 2019, 10:58   #3
Rockeye
I do not have the tool needed to remove the caliper mounting bracket bolts. After some digging on the internet, I was able to find that it needs a size 14 triple square bit. From what I can tell, its basically spline drive. The bolt head however is the female end and the socket attachment is the male end.
Picked this little set up off Amazon. https://www.amazon.com/Capri-Tools-T...NsaWNrPXRydWU=
Apparently no one around my town carries these.
Old July 25th, 2019, 11:31   #4
oilhammer
oilhammer's Avatar
It is most certainly not spline drive. It is XZN, or Triple Square.
Read here:
https://en.wikipedia.org/wiki/List_of_screw_drives
VAG has been using XZN on fasteners since 1968 (at least), so nothing new. Other manufacturers use them too. There are lots of them on that car. And the bolts it question are VERY TIGHT, so the cheap stuff may break.
oilhammer
Old July 25th, 2019, 11:39   #5
alext91
alext91's Avatar
definitely beware of the cheap stuff, I've broken some cheap triple square bits on suspension components before. One of those things worth shelling out for, because a trip to the parts store mid repair is never fun.
2013 Jetta Sportwagen TDI 6MT Pano, Candy White
2015 Golf TDI S 4DR 6MT (Wife's)
2015 Yamaha FJ-09
1999.5 Jetta TDI Tornado Red (Sold)
1996 Yamaha FZR 600 (Sold)
alext91 is offline   Reply With Quote
Old July 25th, 2019, 11:57   #6
Rockeye
Read here:
Forgive me, this is my first German car. Ive seen all sorts of bolts, but these were new to me. Wish it was something I didn't have to special order :/
Old July 25th, 2019, 11:58   #7
alext91
alext91's Avatar
They do sell them at auto parts stores, when I broke one recently I was able to get one at AutoZone
2015 Yamaha FJ-09
Old July 25th, 2019, 16:12   #8
Rockeye
I checked every auto parts store in my area (Auto Zone, NAPA, Advanced, O'reilly). None had any. I was able to get that set off of Amazon for pretty cheap. Hopefully they will hold up to a brake job. The pads and rotors are trashed. I guess the PO did something. The car was purchased in Virginia and had a recent inspection on it. Im guessing the dealer just "bought" the sticker.
Old August 4th, 2019, 09:08   #9
Racerman27410
ID parts has the correct hardened socket to remove the rear caliper holder bolts..... and yes the bolts were very very tight on mine..... the tool they sell to rotate the piston back into the caliper also worked very well.
https://www.idparts.com/14mm-triple-square-p-1130.html
https://www.idparts.com/metalnerd-re...-vw-p-402.html
Racerman27410 is offline   Reply With Quote
Old August 5th, 2019, 17:40   #10
Rockeye
The set that I got from Amazon worked really well. If I happen to break any of these, I will check out the ones from idparts. One thing I learned from owning Jeeps, is that penetrating oil (PB Blaster) work wonders.
I happened to have an old block style piston retract tool in my toolbox from probably 15 years ago. worked like a charm.
Old August 8th, 2019, 18:12   #11
N2UADTDI
After doing work on our 2009 tdi for the last 10 years, I now have 1/2 drawer in my toolbox dedicated to VW tools. None of the other cars I own use these kinds of tools.
N2UADTDI is offline   Reply With Quote
Old August 9th, 2019, 10:18   #12
Rockeye
Oh God. Don't tell my wife hahaha. Since I returned from deployment there has been something coming in the mail for me almost every day. Granted its all been for something that's going on with either the house, cars, kids, but still.
changing rear brakes, special tools needed? fouillard13 TDI 101 12 June 4th, 2015 07:44
What special tools are required 77machomopar VW MKIV-A4 TDIs (VE and PD) 12 February 9th, 2011 05:48
tools required for DIY grant_gray TDI 101 14 October 14th, 2010 08:32
2006 Rear Brakes, tools and instructions bghartm VW MKV-A5 Golf/Jettas 4 January 27th, 2010 03:16
Special tools required? Ymker VW MKIV-A4 TDIs (VE and PD) 10 January 3rd, 2001 06:28
Page generated in 0.17521 seconds with 11 queries
[Output: 110.06 Kb. compressed to 92.98 Kb. by saving 17.08 Kb. (15.52%)]
