Old July 30th, 2019, 15:42   #16
PRY4SNO
PRY4SNO's Avatar
Fuel Economy: Impressive
Didn't realize this was you, and I replied on the other forum. Glad to hear it worked out for you, my stealership only replaced the EGR filter.
- 2010 GSW 6 speed TDI (333k km & counting): #farmenwagen
- 1992 Audi 80q 20v: the 20vt winter sled (long term project)
- 1990 Audi Cq 20v: #becauseracecar
PRY4SNO is offline   Reply With Quote
Old August 1st, 2019, 12:18   #17
ebain21
Hey everyone, I'm brand new here and I've had my first TDI for a little over a year (emissions fixed when I bought it). I have a 2012 Golf TDI 6M with 65k miles. Last Friday on a longer trip (120ish miles RT), I got a MIL and brought it to a dealer on my way home. They said it was a P2002, no other faults or codes. Per their service manual, they performed a manual parked regen and said it returned no other faults or codes. They also said I just need to drive more to initiate regens, but I'm pretty sure I drive enough (30 mile RT mostly freeway commute and fairly regular longer trips) I didn't think to look at the tailpipe but now that I have it's pretty sooty and I don't recall it having a lot of soot previously. It seems like I'm driving a ticking time bomb, but luckily I have CPO for 8ish more months and emissions warranty till 2022 or 120k miles. Unfortunately I'm stuck with terrible dealer service as a result. Is there anything I can do at the dealer to initiate better service? Do I need to have the EGR fault code as well to indicate a failed DPF?
ebain21 is offline   Reply With Quote
Old August 1st, 2019, 13:14   #18
calimustang
Go to other dealership. They wasted your time. It needs DPF replaced as you said the tailpipe is sooty. Thats hard core evidence right there. They are being lazy and avoiding to do the hard job. Not cool at all in my book.
2011 JSW TDI retired and buyback w almost 300k miles.
2015 Passat TDI DSG
2014 JSW TDI DSG
1989 Mustang GT and 89 Ocala FL SSP coupe 5.0 5MT
calimustang is online now   Reply With Quote
Old August 1st, 2019, 13:21   #19
calimustang
If none other than the only stealership thats only local to you then call VWoA and lodge an compliant so they will burn their arses to get you to come over and make you happy.
2015 Passat TDI DSG
2014 JSW TDI DSG
Old August 1st, 2019, 13:49   #20
ebain21
I'll give them a call and see what they'll do. I've driven 180 miles since and no codes, but I'd expect it'll throw a MIL sooner rather than later. I just don't want to cause damage to the EGR or any other components that wouldn't be covered under a warranty. This was my first time at that dealership that is reportedly far better than the one I bought it from. I've had a lot of issues with the dealer I purchased from as well. Why do I feel like I'm constantly getting the wool pulled over my eyes at every dealership? So frustrating.
Old August 1st, 2019, 16:09   #21
ytjetta
I was told the part 1K0-254-708-GX is in back order nationally and that they are #300 or so in the queue. in the meantime, they told me it was ok to drive the car even if the CEL is on. Hopefully they will get it next week.
ytJetta
ytjetta is offline   Reply With Quote
Old August 1st, 2019, 20:27   #22
ebain21
Well I think we have identical issues. 303 miles from the dealer visit and near the end of a 60 mile trip in which had plenty of opportunity for regen, I got the MIL again. I’ll give my dealer a call tomorrow and see what they say... It seems like this is a huge issue and I’m concerned with the low mileage in which failures are occurring.
I’d be concerned to keep driving it with a failed DPF. From what I’ve read, if the DPF is not functioning properly, you can clog the EGR filter and subsequently damage the intake side of the turbo. If the dealer tells me to drive on it, I’m going to push for a rental.
Old August 1st, 2019, 20:56   #23
calimustang
Default Dreaded p2002 fault
And best to have it on black and white paper in case VWoA wanted proof that they told you that it is ďokĒ to drive them with the DPF clogged.
If I were you, force them to give you a loaner while your car sits there until they get the part and replace it.
Im in Florida and no emission check here therefore I didnít care for warranty so I opted for the deleted exhaust kit with tune and upgraded beefed up turbo and never look back.
Purchased my JSW on Sept 2018 with 27k miles and deleted job on 46k and now 51k few weeks later and am truly enjoying the newly founded power and better MPG.
2015 Passat TDI DSG
2014 JSW TDI DSG
Old August 5th, 2019, 13:29   #24
ebain21
Finally heard from the dealer. DPF bad at 65k. Service advisor thought the EGR is included in the DPF replacement, but I'm definitely going to double check that they at least inspected it. They said I could drive it while the DPF is on backorder and I told them I'll keep the rental that VW is paying for. Fingers crossed the next one lasts more than 65k miles or it's definitely getting deleted.
Old August 5th, 2019, 14:19   #25
calimustang
Good! Make sure you use black marker and mark them so you will know if its new or old.
2015 Passat TDI DSG
2014 JSW TDI DSG
Old August 16th, 2019, 13:59   #26
ytjetta
Repair now completed with the replacement of the exhaust pipe (VW speak for DPF) and the aft temp sensor (EXHAUST GAS TEMPERATURE SENSOR
CIRCUIT BANK1 SENSOR 4).
ytJetta
2014 JSW TDI at 50k
Old August 16th, 2019, 17:40   #27
calimustang
Wow your car is so young. Im fully deleted on 2014 JSW since 46k miles. CP3 just installed last week
2015 Passat TDI DSG
2014 JSW TDI DSG
Old August 24th, 2019, 13:59   #28
DivineChaos
Originally Posted by ytjetta View Post
The check-engine light came on during the extremely hot weekend. Using the obd-eleven thingy, I read off the "particulate trap bank 1 efficiency.." i.e., the p2002 fault. Also noticed that the tailpipes are sooty black most probably due to DPF failure. Drove it to dealer this morning and awaiting their verdict. hopefully it will be covered by the extended emissions warranty.
Did any of you had DPF failure this early in mileage? Let me know.
ytjetta
2014 JWS TDI
47400 miles
I have that code. It comes and goes. Waiting on a dpf replacement. about a month out now.
DivineChaos is offline   Reply With Quote
Old August 24th, 2019, 16:35   #29
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
The check-engine light came on... the p2002 fault. ...
ytjetta
2014 JWS TDI
47400 miles
Originally Posted by Vpstang View Post
I just had a DPF replaced last week under warranty.
2012 JSW with 124k
Originally Posted by calimustang View Post
My old JSW lasted on original DPF until 180k something.
Originally Posted by ebain21;5526134[B
] It seems like this is a huge issue and Iím concerned with the low mileage in which failures are occurring.
[/B].
Finally heard from the dealer. DPF bad at 65k. Service advisor thought the EGR is included in the DPF replacement, Fingers crossed the next one lasts more than 65k miles or it's definitely getting deleted.
2014 JSW TDI at 50k
Just in this thread alone it shows the incredible DPF failure rate.
My concern has been why?
Short around town vrs highway?
Would idle before shut down be helpful(turbo timer)?
What can we do as owners of these cars to eliminate this issue which has gotten worse after fix.?
I know the answer is delete/tune, but I live in a smog check area... so....
I bought an 11 as a low mile/use/around town back up car but that type of use it sees seems the worst thing I could do. I.E. DPF life. Fortunately its a CPO w/ brand new DPF and overall like new condition. The next 2 years the warrenty covers may only see 25-30k. My guess it may be saturated... but not enough...?
I think my answer is an interface sold thru Kerma (I cant remember the units name right now). It displays when your regening and soot level, amoung other input on the dash MFD
JELLOWSUBMARINE is offline   Reply With Quote
Old August 24th, 2019, 16:46   #30
calimustang
Hello,
Long time no talk. 5 HPFP failures was because the mechanic(s) neglected to check the fuel tank, it was covered in mold/mildew from sitting 2 years during buyback process. If they checked, there would have no HPFP failures. A lot headaches would have been avoided.
Plus several other problems with Passat that was neglected by the mechanic(s). So I lodged an big lengthy complaint(s) with VWoA for those idiotic mechanics, I am beyond furious and they wasted our time.
Now from on, I do oil changes and such myself.
Anything major such as AC replacement will be covered by warranty, anything else, I wonít bother. I am done with their bullcrap.
Its like if they are hiring monkeys.
2015 Passat TDI DSG
2014 JSW TDI DSG
P13D0 & p2002 ? TurboJay VW MKVI-A6 Jetta Sedan (~ 2011+) 0 July 17th, 2019 22:12
MIL code p2002 IslandLasse TDI 101 6 March 1st, 2019 12:55
P2002 = DPF and a flush joemoto VW Passat Family (NMS and B7) TDIs (2012+) 0 June 22nd, 2018 09:21
Dreaded EGR P0401 fault code... can't find what's wrong foliva VW MKV-A5 Golf/Jettas 6 June 17th, 2018 08:52
P2002 mil code sandmansans VW MKVI-A6 Jetta Sedan (~ 2011+) 11 November 11th, 2016 04:12
Page generated in 0.15268 seconds with 11 queries
[Output: 133.11 Kb. compressed to 112.02 Kb. by saving 21.09 Kb. (15.84%)]
