Old July 16th, 2019, 18:59   #1
yahmon
Default codes after replacing ac condenser and radiator fan
Replaced the condenser and radiator fan on my 2010 tdi jetta and when i go to start it to charge the AC all hell breaks lose, it started first but wouldn't run right, just like someone turn the power on and off. Then it stalled and wouldn't start at all. Performed fuel pump test and all seems in order. Decided to hook up vcds and noticed during cranking that the fuel pressure stays down but once and a while spikes up and all of a sudden start. managed to keep it running for a bit and got these readings and wonder if others have run into this before. Also lost the fan inside too in the process. It sure indicates a power supply or ground problem I think.
3 Faults Found:
001648 - Glow Plug Module 1; Glow Plug Circuit
P0670 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.14
Time: 10:28:28
Freeze Frame:
RPM: 184 /min
Speed: 0.0 km/h
Voltage: 12.69 V
Temperature: 17.1C
Bin. Bits: 00010000
Time: 1.98 s
Temperature: 16.2C
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Freeze Frame:
RPM: 253 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Pressure: 8.0 bar
Inj. Quantity: 24.2 mg/str
Lambda: 46.6 %
Lambda: 45.8 %
000401 - Fuel Pressure Sensor (G247)
P0191 - 000 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 182700 km
Time Indication: 0
Date: 2046.14.22
Time: 00:49:11
Freeze Frame:
RPM: 1771 /min
Speed: 0.0 km/h
Lambda: 4.7 %
Pressure: 864.0 bar
Pressure: 728.0 bar
Pressure: 0.0 bar
Temperature: 18.0C
yahmon is offline   Reply With Quote
Old July 17th, 2019, 03:51   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
What was the nature of having to replace the A/C condenser and fan(s?)? Was the car crashed?
oilhammer
www.cardocautomotive.com
Old July 17th, 2019, 13:21   #3
yahmon
nope, AC wasn't working rock damage on condenser, fins all smashed in and fan had little piece of plastic missing, just decided to fix all at once
Old July 22nd, 2019, 13:24   #4
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Was there other work performed at the time? I cant think of anything that would cause that..
Was the intake hose removed..FF replaced? ETC.
2018 F150 3.5 ECO 3.55 10spd 20s 2tone 26mpg 2turb
2006.5 DE DSG, RC2, Sunroof, 200K miles, 61MPG best
2005.5 Jetta-5 SP LSD Spec S2 130K ELF506 10-30W OCI=20k ORIGINAL CAM RSB Diesel custom 2.5DP/3" SS Pkg 1 Auto-dim mirror auto-WW auto-climate 248tq=150HP RC2 lowered 312 brakes
Mach1 is offline   Reply With Quote
Old July 28th, 2019, 11:46   #5
yahmon
Nope nothing was touched, this thing literally died on the hoist.
Old August 2nd, 2019, 12:40   #6
Mach1
Wow..sounds like fuel system, have you had the HP pump replaced since new?
Old August 11th, 2019, 16:44   #7
yahmon
Why would you think it's the hp pump, it seems electrical to me, even the fan quit.
Check your radiator/condenser fan operation NOW DanG144 VW MKIV-A4 TDIs (VE and PD) 1915 August 21st, 2019 16:37
A5 Climatic and Climatronic Air Conditioner AC and Radiator Condenser Fan DanG144 VW MKV-A5 Golf/Jettas 148 July 1st, 2019 17:19
Fs: mk3 heater core, fan, ac condenser and fan $40 Tdipickup Private TDI Items for Sale/Wanted 0 July 4th, 2015 15:32
a/c slash radiator/condenser fan ? harry3 TDI 101 8 July 17th, 2012 07:53
Check your radiator/condenser fan operation NOW s4phillips VW B5 Passat TDIs 13 January 12th, 2011 15:37
Page generated in 0.14312 seconds with 11 queries
[Output: 82.59 Kb. compressed to 71.19 Kb. by saving 11.41 Kb. (13.81%)]
