Wannaspeed
So a couple months ago my wife was driving the car. She said it just stopped going and was still idling. She turned the car off to let it sit thinking maybe if she gave it some time it will work. She couldn't get it restarted, so I towed her back. I tried to crank it and it acted like it wanted to start, but then it just froze and wouldn't crank anymore.
We had the DMF rattle so my initial thought was maybe the flywheel was trash, maybe lodged in there funny or something. This week I got around to working on it. I separated the transmission and inspected the flywheel. I knew right away that the issue wasn't the flywheel, although it needs to be replaced its structurally intact. So I pulled the timing cover and sure enough several of the TB teeth are completely stripped.
I have no idea if any of the valves contacted the piston while it was idling, But i imagine the reason it would no longer crank is valve contact. At this point I'm wondering the best course of action in inspecting the possible damage.
Should I pull the valve cover and inspect the lifters? Pull the head and inspect the valves and pistons? Advice? thanks. Engine has 190k
