Old March 30th, 2016, 19:13   #16
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
In my experience, Machining cost is about a wash:
NPT = Pre-drill to minor thread diameter then tap - Tapping has to be done carefully as it's a tapered tap. Can't go too deep or too shallow or the mating fitting won't work
SAE = Pre-drill (less than thread minor diameter) then form tool then tap. All are high speed operations
You can get SAE form tools that will drill the rough hole, pre-drill all in one, but they're generally expensive compared to the additional machine time. He's not likely constrained by the machining time anyway.
The NPT tapping/inspection process is also much more controlled/involved than a straight thread port so that end of it typically cancels out any machining time advantage.
All of this may be irrelevant depending on how evguy1 has his process setup.
Fittings/adapters are a negligible cost difference - Can't seem to find the quotes now but they're within a few pennies on a fitting that is less than $2.00 regardless if you're going NPT to JIC, NPT to ORS, SAE to ORS, SAE to JIC, etc
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old July 24th, 2019, 22:14   #17
tims944
TDI(s): 2006 mk5 tdi
PM sent to you ev guy
tims944 is offline   Reply With Quote
Old July 25th, 2019, 06:34   #18
evguy1
This is an old thread. I did change to ORB threads in these plates back in early 2017 along with a few other minor changes.
evguy1 is offline   Reply With Quote
Old July 27th, 2019, 06:33   #19
Dh4276
Pm sent to you ev guy, I know this thread is old.
Dh4276 is offline   Reply With Quote
Oil filter relocation 96powerstroke VW MKIII-A3/B4 TDIs 30 November 22nd, 2015 05:33
Oil ALH oil Filter housing relocation...help me understand. couttsdesign TDI 101 8 May 20th, 2012 09:16
Oil filter relocation Hal TDI Conversions 7 June 6th, 2009 19:23
Oil Filter Relocation? Satiro TDI Power Enhancements 17 April 10th, 2009 03:44
oil filter relocation on passat mittzlepick VW MKIV-A4 TDIs (VE and PD) 1 March 19th, 2001 03:42
Page generated in 0.13450 seconds with 11 queries
[Output: 67.68 Kb. compressed to 61.07 Kb. by saving 6.61 Kb. (9.77%)]
