Old June 13th, 2015, 21:58   #1
mhintlian
TDI(s): 03 Golf GLS
Default Oil Pressure gauge wiring issue.
So I put in a New South oil pressure gauge, and volt gauge in an 03 Golf ALH MKIV TDI. The volt gauge works perfectly even with the lights on. However the oil pressure gauge is presenting an issue. The gauge illuminates properly but the gauge pegs all the way when the engine is running. I contacted New South who provided a replacement sender. The replacement sender is connected to the oil filter housing using a 42 design oil pressure sender relocation kit. The relocation kit is grounded to the block. Even with a new sender the gauge still pegs all the way. So I am assuming that there is a wire crossed. Per the instructions the red from the gauge connects to the red from the sender and continues to the 76X post under the dash. The white from the gauge connects to the white from the sender. The black from the gauge connects to the black from the sender and continues to a ground post under the dash. The yellow wire from the gauge is connected to the grey/blue wire at the light dimmer switch. So where am I going astray here?
mhintlian is offline   Reply With Quote
Old June 14th, 2015, 07:05   #2
Dimitri16V
Dimitri16V's Avatar
is it staying pegged all the time ?
what pressure range is the sender and gauge ?
if I recall correctly , the sender gets switched 12V , it is grounded thru the block and sends a fluctuating voltage to the gauge
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old June 14th, 2015, 10:44   #3
mhintlian
TDI(s): 03 Golf GLS
The gauge range is 0 to 100.
Old June 14th, 2015, 10:45   #4
mhintlian
TDI(s): 03 Golf GLS
The needle goes past 100 all the time.
Old June 14th, 2015, 11:09   #5
mhintlian
TDI(s): 03 Golf GLS
The ground for the oil pressure sender is attached to the ground peg on the block where the trans bell housing attaches to the block above the starter. The sender positive is tied into the gauge positive lead and wired to a switchable positive (the 76X post under the dash).
Old June 15th, 2015, 06:06   #6
Dimitri16V
Dimitri16V's Avatar
What happens if you disconnect the signal to the gauge ?
Can you post a pic of the wiring diagram ? Did yo use Teclon tape in the threads of the sender unit ?
Old June 15th, 2015, 07:13   #7
HogWrangler
Banned
Can you post a pic of the gauges mounted? I've been looking in to getting an oil pressure, volt, and boost gauge
HogWrangler is offline   Reply With Quote
Old June 15th, 2015, 08:01   #8
Dimitri16V
Dimitri16V's Avatar
If you do , get VDO gauges and parts .
Old June 15th, 2015, 11:16   #9
HogWrangler
Banned
Thanks! I haven't looked at them yet. I'm wanting them to match as close as possible to stock and look factory. My biggest hangup is deciding on where I want to mount them so that they blend as best as possible like factory.
Old June 16th, 2015, 13:30   #10
mhintlian
TDI(s): 03 Golf GLS
When I disconnect the sender the gauge goes to zero. I did not use teflon tape on the sender threads. Will send photo.
Old June 16th, 2015, 13:32   #11
mhintlian
TDI(s): 03 Golf GLS
Mounted gauges in the center console. above radio, which is not OEM 3 in 1 but a Kenwood. The space left as a result of the smaller radio is perfect for gauges. Photo to come shortly.
Old June 16th, 2015, 14:17   #12
HogWrangler
Banned
Thanks! Unfortunately I have the Monsoon
Old June 16th, 2015, 17:52   #13
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
Have you contacted the gauge vendor ? Good chance they have experienced the issue before and may be able to help you quickly along the diagnostic path.
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old June 16th, 2015, 19:52   #14
Bran Diezel
Bran Diezel's Avatar
Fuel Economy: 50mpg
Gauges are usually simple.
Reads 0 = open circuit
Reads 100 = shorted to ground
Bad sending unit even though it's new, gauge could be bad but there's one more thing, is the sending unit touching the engine or anything that is metal on it? If so and you don't have a nylon washer or the like isolating the signal from the unit then it is grounded and shorting your signal to ground rather reading resistance on the post. Have you tried ohming the sending unit?
Bran Diezel is offline   Reply With Quote
Old June 16th, 2015, 20:27   #15
Dimitri16V
Dimitri16V's Avatar
He probably has the dual sender and he is using the terminal that replaces the stock oil switch
Oil Pressure/Temp Gauge at Turbo Oil Feed Line? arne487 Upgrades (non TDI Engine related) 9 September 25th, 2012 01:27
Oil pressure gauge, need help!! kbrenny Upgrades (non TDI Engine related) 11 July 30th, 2008 04:31
Oil Pressure gauge imkemfly TDI 101 14 December 14th, 2007 12:47
oil pressure sendor wiring question iamatt Upgrades (non TDI Engine related) 3 June 28th, 2007 14:51
EGT and Oil Pressure Gauge ?s - Oil leak! quadboss74 TDI 101 5 June 22nd, 2007 17:18
Page generated in 0.16527 seconds with 11 queries
[Output: 123.62 Kb. compressed to 102.38 Kb. by saving 21.24 Kb. (17.18%)]
