Beemer1972
Hi guys. New to the page. Cut a long story longer. Got a 2001 passat 1.9 pd130 for �0„5600. Had to do the normal things like the timing belt that was about 80 thousand miles overdue lol. The front brakes that were well past it. They got done by a tech i know. Then i did the stuff i could do myself. The vac hoses. Cleaned the egr and found that the long pipe from it that goes to the bottom of the engine (not a tech so do not know what you call it) was very very restricted with build up. Trouble is the plank who has had it before has rounded one of the two bolts that Hold it to the engine. I want to clean the turbo out as its done 163 thousand and its a guessing game when you will get boost. The rod moves up and down to a degree when you rev it but there is not a lot of power and it drops off many times. How can i get the pipe off to clean it and also clean the turbo out. I am stuck. Thanks in advance.
