Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old September 2nd, 2012, 21:24   #31
LexDube
Exactly, turned lights on and it started melting out the wires and smoking as hell. I didn't wanted to let them on for too long so I quite didn't pinpointed the problematic wire and also I think it messed with the intensity of the low beam as i found the lights to be less effective before starting wireBQing. gonna try turn on low beam with the climatronic disconnected to see if my clim harness is the problem but if it was that the climatronic would surely malfunction (as the wiring is point to point like yours) plugged correctly, all the wires crimped and all
LexDube is offline   Reply With Quote
Old September 3rd, 2012, 09:25   #32
sinc
sinc's Avatar
TDI(s): None
Which wires melted? The headlight or the climatronic wires?
mk2 wookie
sinc is offline   Reply With Quote
Old September 3rd, 2012, 09:31   #33
LexDube
The headlight ones the climatronic harness seems to be fine
Old September 4th, 2012, 04:13   #34
sinc
sinc's Avatar
TDI(s): None
Hmm unless you changed the wires on the headlights somehow I don't see that happening cause of the climatronic harness.
mk2 wookie
Old September 5th, 2012, 11:38   #35
LexDube
Its seems that the ground wires are the victims of this wireBQ I guess its my climatronic ground that have the trouble could it be a bad contact inside my crimp or a bad ground location
Otherwise a ground for my headlight or the battery must be bad or something as the main beam definitely lost power
Old September 5th, 2012, 11:44   #36
LexDube
And where did you put the ground on your wiring?
Old September 5th, 2012, 15:18   #37
sinc
sinc's Avatar
TDI(s): None
There is a ground by the passenger seat right foot that I used.
mk2 wookie
Old September 5th, 2012, 18:05   #38
LexDube
The same point as the fan ground. I guess the grounding point next to the steering column on the dash bar may be too crowded
Old September 8th, 2012, 14:38   #39
LexDube
It seems that my crimp was loose I tightened the connection and it looked fine for now
Old September 9th, 2012, 05:50   #40
sinc
sinc's Avatar
TDI(s): None
Ah well hope it all works for you now!
mk2 wookie
Old September 15th, 2012, 14:27   #41
gsrsilver
gsrsilver's Avatar
TDI(s): Golf mk4
Fuel Economy: Little better than Graeme's
I want to know more about climatronic swap
gsrsilver is offline   Reply With Quote
Old September 15th, 2012, 15:50   #42
sinc
sinc's Avatar
TDI(s): None
What more do you want to know?
mk2 wookie
Old December 8th, 2015, 05:59   #43
magaizeris
TDI(s): VW Bora
Up, please can tell me how test climatronic at home? i Have battery charger and how connect + to blue/black and - to brow, my climatronic blinking. Fan not connect
https://www.youtube.com/watch?v=u9Y0AQwGz8c
magaizeris is offline   Reply With Quote
Old October 14th, 2016, 11:25   #44
mehdi00golf
TDI(s): golfmk4
Hello, I has a golf 1.6 16v with manual air conditioning, I would like to install a climatronic I recover all the parts for this transformation, only I have some questions the first are that the transformation is performed in the same manner as for a golf tdi ? , secondly about the orange connector t/10, the location t10/7, t10/8 and t10/9 are already occupied, es I have to cut them and replace them with the electric beam I prepare ? , thanks.
mehdi00golf is offline   Reply With Quote
Old July 28th, 2019, 13:34   #45
LordGunner
Fuel Economy: 58 Highway 41 City
Default T17/7
T17/7 isnít in your guide but in the Bentley manual it says it goes to the T14/4 on the fan control module. Do I NEED to hook this wire up or will it work with the current instructions youíve provided?
LordGunner is offline   Reply With Quote
help: mkiv climatronic swap sinc Upgrades (non TDI Engine related) 55 August 25th, 2014 14:55
Climatronic Swap....I saved the best for last greekdubber Upgrades (non TDI Engine related) 51 September 17th, 2012 11:30
WTB: MKIV Climatronic air hanlder box for swap tamorgen Private TDI Items for Sale/Wanted 3 July 27th, 2009 06:38
climatronic complete swap alex97jazzblue Private TDI Items for Sale/Wanted 10 October 20th, 2007 13:24
climatronic complete swap alex97jazzblue Upgrades (non TDI Engine related) 1 September 22nd, 2007 09:41
Page generated in 0.18343 seconds with 11 queries
[Output: 119.14 Kb. compressed to 98.38 Kb. by saving 20.76 Kb. (17.42%)]
