Old February 25th, 2019, 06:19   #5386
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Lots of people reported that the VW TSB did not really fix the issue. Just helped in a few marginal cases.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old March 2nd, 2019, 19:39   #5387
ATR
ATR's Avatar
Originally Posted by B25guy View Post
Thanks for the reminder. After more thought, I think not covering my lower front this winter may be the cause of the re-occurrence. I installed a tow plate to be able to tow four down behind my bus and all the brackets are in that grill area. Since I had the TSB installed in 2011, I have covered the lower front with pipe foam every winter but this one. So perhaps the TSB didnít really fix anything?? Next thing will be to drill the drain hole.
Pretty much what kjclow said. Never really helped...
I know when I had my '11 I had the lower cover in place when the winter came on and it really helped speed up warm up times along with preventing the no start condition. I do remember having one time where it was a hard start... but that was before I had the cover in place.
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
Old March 18th, 2019, 20:13   #5388
Mark1331
I have been using the IDparts winter front for while now, and I love it. No more intercooler icing. Also, on a reasonably warm day recently (50 degrees) I took the care through a brush type car wash, forgot I had the winter front on. Everything remained in place nicely, if that is a concern for anyone.
Mark1331 is offline   Reply With Quote
Old March 19th, 2019, 03:06   #5389
Matt927
Matt927's Avatar
TDI(s): several
YES! The easiest fix to intercooler icing along with some other benefits.
Finally took mine off yesterday as we are starting to see highs in the 50s and 60s next week.
Matt927 is offline   Reply With Quote
Old April 9th, 2019, 14:43   #5390
jesus_man
So, after checking for water in my system several times, it finally yielded enough water to be a concern. Trying to think outside the box here, and hoping to brainstorm collectively (unless this has already been done on the previous 359 pages) that there has to be a good solution that does not require a $570 kit + install.
Looking at the diagram, am I correct that we are to remove the rubber hose on the passenger side from the #18 in this diagram?
If so, perhaps someone more knowledgeable about parts could install some sort of drain in that hose with a small valve at the end of it that could be accessible without removing any tools.
Something on the order of a nipple off the bottom of item 18, a length of hose with this at the end.
Then you just open the valve with the engine running and blow out any water with each fill-up or something on that order?
2010 JSW TDI DSG in gray with black interior
2009 JSW TDI DSG - sold back to VW
2002 VW Passat Wagon, 6spd, silver Family hauler! - Euro Spec
2006 Jetta TDI Bought 6/25/06 (traded in 10/2009 @ 43mpg
jesus_man is offline   Reply With Quote
Old April 10th, 2019, 06:43   #5391
kjclow
The suggestion buried either somewhere back in this thread or in another thread is to just drill a small drain hole in the bottom hose and let it drain rather then collect. The problem i see with a valve is knowing how often is often enough to open and close it
Old April 10th, 2019, 09:15   #5392
jesus_man
Agreed, but I also don't like unfiltered air to have a chance of entering the system.
Old April 10th, 2019, 15:15   #5393
PlaneCrazy
TDI(s): Gone...
I'm not so sure. The problem isn't icing, it's condensate accumulating in the intercooler. Ice will clog it, but a slug of water can be sucked into the engine at any temperature. On my Mk VI, this happened numerous times even in +30C weather in summer. It would happen after about two weeks of accumulation. I'd pull out to pass a farm vehicle or something, nail the throttle, be in the left lane, and I'd lose all power. Very disconcerting with on-coming vehicles looming.
The only cure to that was an "Italian tune-up" at least once a week. My wife's Mk 5.5 wagon (2013) on the other hand, never had an issue and never had the intercooler kit installed, while my 2011 hatch, had the kit and it did zilch.
Mike
Hers: '17 Golf TSI Sportwagen 5-MT
His: '18 Sportwagen 6-MT 4MOTION
'16 Marinoni Genius/Campy Record, '94 Marinoni Special/Campy Record
PlaneCrazy is offline   Reply With Quote
Old April 11th, 2019, 10:07   #5394
Matt927
Matt927's Avatar
TDI(s): several
Never had an issue above freezing. Warm moist EGR mixing with cooler air, condensing and then freezing caused a few rough starts running no cover. I am on my third CJAA equipped car and never had a no start or any water in the intercooler related issues causing damage, hundreds of thousands of miles on them. One car had the fix, never an issue with that car either.
Golf tdi 99 hard start from cold and yesterday won't start at all deep_sing VW MKIV-A4 TDIs (VE and PD) 17 December 13th, 2013 06:48
TDi 130 PD - Hard Start When Cold, No Start When Hot ginboomerang VW MKIV-A4 TDIs (VE and PD) 5 July 12th, 2011 11:36
Hard Start Plus Check Engine Light and Blinking Glow Plug Indicator Greg_Morgan VW MKIV-A4 TDIs (VE and PD) 13 December 21st, 2006 16:21
No Glow? Hard cold start? Check coolant temp sensor. Jimmy TDI 101 3 January 29th, 2006 07:27
Check Eng Light - Hard start - glow plug - $$$ basco2 VW MKIV-A4 TDIs (VE and PD) 9 January 27th, 2001 18:28
Page generated in 0.18494 seconds with 11 queries
[Output: 97.09 Kb. compressed to 83.83 Kb. by saving 13.26 Kb. (13.66%)]
