Old November 17th, 2010, 09:00   #1
DieselDenny
TDI(s): 96 Passat
Default Clutch Problems
Is there a way to tell whether a clutch problem is related to the clutch parts themselves or the hydraulic sytem....master and slave cyls? My clutch does not want to disengage......I changed out the slave but still no different. When bleeding the system there seemed to be a good solid stream of fluid coming from the bleeder so I'm thinking the master cyl is OK. Would bad/worn clutch parts cause the clutch to remain engaged? I was always under the impression that the clutch would begin to slip when worn out. The car has about 210,000 miles on original clutch. Any help with this would be greatly appreciated.
DieselDenny is offline   Reply With Quote
Old November 17th, 2010, 09:32   #2
jollyGreenGiant
jollyGreenGiant's Avatar
The spring in the clutch disk fails and wedges itself between the PP and the flywheel...
jollyGreenGiant is offline   Reply With Quote
Old November 17th, 2010, 09:46   #3
other-power
other-power's Avatar
Fuel Economy: 55mpg
Put in a new clutch, you have had your moneis worth!
Regards
other-power is offline   Reply With Quote
Old November 17th, 2010, 09:52   #4
jollyGreenGiant
Actually that one above had 176K on it and the material itself would have had a lot left.
Old November 17th, 2010, 13:29   #5
other-power
Fuel Economy: 55mpg
I am sure it did but no springs will hold out that long. If nothing else it will save you having to wear a lead foot to change gear.
Old November 24th, 2010, 17:10   #6
Glennbo
Just did my clutch after 220,000 miles. Springs were loose in disc and wearing into surrounding metal.
Glennbo is offline   Reply With Quote
Old March 10th, 2011, 10:53   #7
DieselDenny
TDI(s): 96 Passat
FOLLOW UP....I changed out the clutch parts and the springs were broken like the ones pictured above (jollygreengiant's post). Thanks guys.
Old March 11th, 2011, 16:13   #9
BlindViper
TDI(s): 97 A3
My clutch was done at 112k because I had the trans out. The clutch material on the new and old measured the same. But the springs were shot.
BlindViper is offline   Reply With Quote
Old March 12th, 2011, 00:58   #10
sfierz
Fuel Economy: 54/42/35
That's how mine went, too, at 200k miles--the spring popped out and wedged itself between the clutch and PP.
sfierz is offline   Reply With Quote
Old March 16th, 2011, 11:33   #11
rhaus
when your clutches went out in this way, how did the clutch pedal feel? The same? Different? I am having the same symptoms but my pedal feels completely different now, as if there is air in the lines.
2012 Golf TDi
rhaus is offline   Reply With Quote
Old March 16th, 2011, 20:02   #13
jollyGreenGiant
This clutch failure modes symptoms are that the clutch works perfect all the way up till you simply can't disengage it. I was able to temporarily disengage the one above but it went right back.
Old March 17th, 2011, 18:03   #14
rhaus
Mine worked perfectly right up until the stopped disengaging, but now that it won't disengage, the pedal feels like there is nothing until right before the floor.
2012 Golf TDi
Old March 17th, 2011, 18:12   #15
jimmybling31
At 232k my clutch was still fine just wouldn't hold the power of the vnt 17/22. As soon as it would hit full boost it would slip just a bit. The clutch in these cars is very good
2001 Jetta gls TDI- 19" rims, kenwood head unit, pioneer speakers all the way around, sprint520, ported head, ported intake manifold, vnt17/22, upgraded intercooler pipes, egr delete, kerma tdi tune, race pipe, straight through exhaust system, soon race520 nozzles.
1994 Camaro z28- building high horsepower nitrous motor for it.
jimmybling31 is offline   Reply With Quote
Page generated in 0.15539 seconds with 10 queries
[Output: 118.40 Kb. compressed to 97.61 Kb. by saving 20.79 Kb. (17.56%)]
