Old January 14th, 2010, 17:34   #1
sullyTDI
sullyTDI's Avatar
Fuel Economy: 42+
Default Clutch Release Lever Failure - Clutch/Shifting Problems Fixed
Wanted to throw this out there for information.
My 98 Beetle TDI Started having problems going into gear almost over night. (Original Clutch)
Was like hard to go into first, and fifth where the worst others where hard to, reverse would grind.
I knew from reading the forum posts, that the clutch wasn't releasing properly.
So I check the fluid and it was to the minimum mark. So, that ment air in the clutch system, I bled, and bled and bled. No change.
Anyway, took it to my trusted mechanic, he thought the same thing I did. He bled and bled. Nothing.
So we decided it was something in the clutch broke. He pulled it and low and behold, the clutch release lever,
steel had failed, cracked and bent 1 1/2" out, severly limiting clutch release.
Here is a photo borrowed from IDParts.com showing where it had cracked and failed. As this one is shown, cracked and the end bent downward.
Edit: This must have been going on a while, we replaced the clutch and lever, an now shifts better than it ever has..
Stephen
98 TDI Beetle, Red, 5 Speed
Sprint 520's, RC3, Sachs Clutch, Muffler Delete,
Custom Side Markers, Euro Headlight Switch, Euro Rear Fog, OEM 1.9L TDI Emblem,
Mobil 1 0w40, MANN Filters,
sullyTDI is offline   Reply With Quote
Old January 14th, 2010, 20:12   #2
Victor Huge
Victor Huge's Avatar
TDI(s): Mk7 Golf TDI
Interesting. I love when people post this stuff, really really helpful if a problem like this arises for us. Thank you!
Victor Huge is offline   Reply With Quote
Old January 15th, 2010, 08:08   #3
sullyTDI
sullyTDI's Avatar
Fuel Economy: 42+
Just wanted to bump it back up.
Stephen
Old January 15th, 2010, 11:39   #4
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I gotta say this is good info to share...
(seen it before but not on a VW)
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old January 18th, 2017, 08:52   #5
jagster936
Default Similar Situation
I had grinding issues in 02 ALH and pulled the tranny. Turns out the clutch release lever had hole worn in where it pivots and the pivot bolt was well worn. 473k miles cannot blame her
jagster936 is offline   Reply With Quote
Old January 18th, 2017, 10:21   #6
Nevada_TDI
My suggestion: always replace the clutch lever, pin, and clip whenever the transmission is out.
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old January 18th, 2017, 10:30   #7
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
You are not alone. This is an issue careful inspection during replacement is needed. In your case well it is life. Just think of how many times the clutch is used over 19 years. Dang it my old leg is starting to hurt.....
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old January 18th, 2017, 10:57   #8
jagster936
Haha yep! The lever was rubbing on flywheel lol
Old January 18th, 2017, 13:54   #9
sisyphus
sisyphus's Avatar
Same here, on an '01 with a little over 230k.
sisyphus is offline   Reply With Quote
Old January 18th, 2017, 14:02   #10
jagster936
I don't know why people say rated life is 500k on these cars. With highway miles I bet it's more like 700k. This was original clutch and turbo too!
Page generated in 0.15700 seconds with 10 queries
[Output: 93.79 Kb. compressed to 79.09 Kb. by saving 14.71 Kb. (15.68%)]
