Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old February 11th, 2008, 15:21   #1
TyeRant
TyeRant's Avatar
Default Certified Pads from CT any good?
A buddy told me that brake pads were on clearance for 65%off at CT. Both front and back were $18.79 plus tax a set.
Two questions though...
Are the Certified pads from CT any good?
and
How do I tell if I have 280mm rotors or 288mm rotors without freezing my fingers off measuring??
TyeRant
2003 Jetta Wagon
Stock for now
TyeRant is offline   Reply With Quote
Old February 11th, 2008, 15:51   #2
OmegaRenegade
OmegaRenegade's Avatar
TDI(s): 2004 Jetta
I think they would do for average use - light load but if you like hammering it, they fade pretty quick just my experience with them. you get what you pay for.
2004 Jetta TDI 5 Speed 420 000km PD130 ASZ Engine
SLIGHTLY Modified
OmegaRenegade is offline   Reply With Quote
Old February 11th, 2008, 15:59   #3
LNXGUY
LNXGUY's Avatar
Can't beat $20 for pads..
You have 280mm rotors.. 288mm's are on the 1.8T and VR6.
Bill
LNXGUY is offline   Reply With Quote
Old February 11th, 2008, 17:42   #4
TyeRant
TyeRant's Avatar
Thanks,
I thought it may be something to do with some sort of factory upgrade.
I got the 280mm. I am a pretty tame driver. These should do me fine. Besides, couldn't pass up this deal. Pads all around for under $44 tax in!
TyeRant
2003 Jetta Wagon
Stock for now
Old February 11th, 2008, 19:27   #5
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Personally I consider brakes a safety item. I always use an excellent quality pad on all my cars. Including beaters. The CTC crap doesn't hold up in my books.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old February 11th, 2008, 19:42   #6
OmegaRenegade
TDI(s): 2004 Jetta
i share the same sentiments as you Uberhare. Definatley noticed a BIG difference in braking power between the cdn tire discount stuff and the Brembo / Pagid brands.
SLIGHTLY Modified
Old February 12th, 2008, 02:37   #7
RichDiesel
RichDiesel's Avatar
Right now I have CT pads (Munro) and rotors on the front of my beast and they work just fine.
I do mainly highway driving (80km/h speed limit) for long stretches of time. If I were on the 400 series highways, and I felt a difference, I might be inclined to spend a bit more $$ the next time around. But for the type of driving that I do, they are more then satisfactory.
...and you can't knock the price.
I blame TDiClub for the following: Ventectomy, AlienTech, , Sprint 520's, VR6 Clutch & Flywheel, Aluminum Skid Plate, Kerma Tuned, ScanGauge II, Sirius Satellite Radio, BORA TDI Badge, 342,000kms...and counting. FaceBook, Timing Belts: 2
RichDiesel is offline   Reply With Quote
Old February 12th, 2008, 13:06   #8
weasel
Deactivated Member Account
TDI(s): None.
Certified pads are on their way to being discontinued at CT, being replaced by NASCAR branded pads. Don't know anything about the new pads ...
weasel is offline   Reply With Quote
Old February 13th, 2008, 13:06   #9
craig01b
craig01b's Avatar
TDI(s): None
Good price, and fair parts. If you are a typical daily driver, go for it. Nothing wrong with them. There are better out there for sure, but, they will perform perfectly well. I would install them, and not give it another thought.
That being said, I have brembo's and pagids on my car....Its all about money....and how much you want to spend for a little better performance. And I believe, the first stop would be as good with them as any others....its the 2nd and 3rd where you will have issues. But, as a daily driver on a highway, this is not really an issue.
Craig
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Page generated in 0.12682 seconds with 10 queries
[Output: 87.81 Kb. compressed to 74.28 Kb. by saving 13.53 Kb. (15.41%)]
