Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old May 26th, 2007, 17:08   #1
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
Default Remote control window roll-up/down
A few people I had talked to today at Shay-dee-acres wanted to know if it is possible to use a Vag-Com to program your older VW to operate the windows with your remote like the newer 05/06 or Audis can do .
Well I found this website and there is a write up and instructions how to do it and some more comments from other people.
http://www.passatworld.com/forums/ar.../t-219402.html
Here it is from that website not written by me!.
I can't find anything about it here on the forums so I decided to post this information here. A while ago some clever geniuses in Germany discovered that you can modify the software of the central convenience control module so that it works like it does in Audi cars for ages and it does in the newer VW.
Press and hold the open button on your key fob and the windows roll down
Press and hold the close button on your key fob and the windows roll up
What do you need to do to get this to work?
1) a laptop or pc
2) a serial vag-com cable. Not all of them work for this. ProChip and orignal Rosstech interfaces are known to work in most cases
3) a pretty old dos only software called VDC Pro
I found two links to the software on it on the internet:
Mirror #1 (Bootdisk included) (http://rapidshare.de/files/25819996/vcd_boot.img.html)
Mirror #2 (VDC only) (http://www.vege-duewels.de/VDC_PRO.zip)
You can't do this from any windows version (Dos only!), with any USB interface or with VAG-COM or a VW 1551 tester.
Use the following procedure to reprogram the module
1. start vdc
2. connect to central convenience (46)
3. start login procedure (11)
4. use the code 19283
5. read serial eeprom (26)
Find the list of known values further down this post. Write down the original values at and continue.
6. write serial eeprom (27)
Enter the memory address and value mentioned in the list down below.
Do this for all addresses mentioned
7. end output (06)
Now exit your car and lock it. When you now open your car with the key fob and hold the button the windows should start to roll down and stop when you lift your finger.
This works for all VW/Seat/Skoda cars that use the same type control module. Passat B5, B5.5, Golf Mk IV, Seat Leon, Jetta, Bora...
The following codes have been collected on different boards in Germany for the listed modules:
1J0 959 799 AH (any index) and 1J0 959 799 S 03B
Memory Address / old value / new value
04283 / 8 / 2
04289 / 8 / 2
08628 / 242 / 246 driver side front window
12724 / 250 / 254 passenger side front window
16280 / 250 / 254 driver side rear window
20916 / 242 / 246 passenger side rear window
1J0 959 799 J 00E
04286 / 8 / 2
04291 / 8 / 2
04296 / 8 / 2
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Variant/Wagon
04361 / 75 / 67
04362 / 75 / 67
04363 / 75 / 67
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Limousine/Sedan
04361 / 74 / 66
04362 / 74 / 66
04363 / 74 / 66
If you find any more codes/version/control modules where this works please post the codes here.
If it doesn't work just put your old values back in there and no harm is done.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old May 26th, 2007, 17:19   #2
GD
GD's Avatar
Does this mean we don't need to install the alientech module?
TDI'ers Do it Better!
2007 Benz ML320 CDI too many toys to list
2011 Jetta TDI (CJAA) Highline DSG Reflex Silver 165,000 kms
2004 Jetta TDI PD (BEW) Platinum Metallic Grey 340,000 kms SOLD
2000 Jetta TDI ALH Black 398,000 kms, TT LCA Bushings, TB changed at Windex GTG SOLD
GD is offline   Reply With Quote
Old May 26th, 2007, 17:42   #3
OmegaRenegade
OmegaRenegade's Avatar
TDI(s): 2004 Jetta
i am with GD i thought the only way we could get it to work was with that module
2004 Jetta TDI 5 Speed 420 000km PD130 ASZ Engine
SLIGHTLY Modified
OmegaRenegade is offline   Reply With Quote
Old May 26th, 2007, 18:29   #4
Jetta_Pilot
I'm just passing on the info I found. I installed my Alien Tech today at Shaydees, but this info I found after I got home and did a search on the web.
Old May 27th, 2007, 08:01   #5
LNXGUY
LNXGUY's Avatar
I can operate the windows via the keyfob in my dads '06? lol awesome
Bill
LNXGUY is offline   Reply With Quote
Old May 27th, 2007, 09:48   #6
GD
GD's Avatar
Links don't seem to work?
Old May 27th, 2007, 12:37   #7
weasel
Deactivated Member Account
TDI(s): None.
I thought I had seen this discussed before and was of the understanding that it will NOT work with KEY-COM cables. It will work with the older cables or the ones off fleabay though ...
weasel is offline   Reply With Quote
Old May 27th, 2007, 12:51   #8
Jetta_Pilot
As I said before, I only posted it. Read the Passat forum for more info!
Old May 28th, 2007, 05:36   #9
fitzski
fitzski's Avatar
Plenty of discussion on this around TDI Club. Start here, or search for "vds pro":
http://forums.tdiclub.com/showthread.php?t=151041
Currently dubless, but formerly:
2004 Jetta TDI-PD [galactic blue, black & tan, 5sp] (Sold.)
2003 Passat W8 Variant [pacific blue, tan leather, 6sp] (Sold.)
2004 Jetta TDI-PD [spice red, black leather, 5sp] (RIP)
fitzski is offline   Reply With Quote
Old August 5th, 2019, 07:09   #10
locarno
TDI(s): 1.6 16V
Hello
If I change only adress for front window
04289 / 8 / 2
then I got only front window remote and rear widnows will not open ?
locarno is offline   Reply With Quote
Old August 5th, 2019, 17:52   #11
ErackTDI
theres a much easier way then this if anyone is interested
https://youtu.be/KQNJzkJtIPg
ErackTDI is offline   Reply With Quote
Old August 6th, 2019, 02:26   #12
locarno
TDI(s): 1.6 16V
Where to download this software ?
With this software I not need to get RS232 cable ?
Old August 6th, 2019, 05:27   #13
ErackTDI
in the video discription there is a link
and on that link there is links to cables
Old August 6th, 2019, 07:56   #14
locarno
TDI(s): 1.6 16V
This software in only in Cesky language.
Old August 7th, 2019, 08:43   #15
ErackTDI
yes but very easy to use and if u follow a video about 2 mins total including laptop boot up lol
2 buttons and your done.
Page generated in 0.17198 seconds with 10 queries
[Output: 123.42 Kb. compressed to 102.37 Kb. by saving 21.05 Kb. (17.06%)]
