Old May 30th, 2002, 10:05   #1
christi
christi's Avatar
Default bore out 1.9 to 2.0
I was just doing some dreaming here...
Pistons from a 1Z motor are 79.5mm diameter.
Pistons from a five cylinder 2.5 TDI (AAT) are 81mm diameter.
Early 1Z and AAT both use the same part number for the circlip (that holds rod pin in piston).
So maybe an AAT piston could fit on a 1Z conn rod...
Now, going from 79.5mm to 81mm is a 3.80% increas in surface area.
That takes a 1Z motor from 1896cc up to 1968cc.
Unanswered questions:-
1. Will an AAT piston fit on a 1Z conn rod?
2. Is an AAT piston shorter or taller than a 1Z piston? If its a little shorter then we might be able to reduce compression ratio too [img]images/icons/cool.gif[/img]
3. What other rods might fit? The bearing shell for the big end are different though...
What we need is a piston from a scrapped Audi 100 TDI to compared with a 1.9 TDI.
christi is offline   Reply With Quote
Old May 30th, 2002, 10:42   #2
Davin
Default Re: bore out 1.9 to 2.0
Interesting. What about the combustion bowl? Same design?
Davin is offline   Reply With Quote
Old May 30th, 2002, 11:42   #3
TEXAS_TDI
BANNED
I like your thinking.... [img]images/icons/cool.gif[/img]
TEXAS_TDI is offline   Reply With Quote
Old May 30th, 2002, 14:54   #4
tdi rs
TDI(s): mk2 16v tdi
Guess what i'm in the middle of doin!!!
i've got the pistons and the blocks bored out.
The piston are the same as a 1.9tdi but with a slightly bigger bowl in the top.
tdi rs is offline   Reply With Quote
Old May 31st, 2002, 01:50   #5
christi
christi's Avatar
...which will give a lower compression ratio I guess [img]images/icons/cool.gif[/img]
Are you using 1.9 conn rods? Do they fit straight onto the 5 cyl pistons?
Where are you going to get a head gasket from?
Old June 1st, 2002, 14:10   #6
therabbittree
therabbittree's Avatar
TDI(s): B4 passat
ok i have a ?..the 1z engine's pistons do not have the bronze reinforced pin bores or the teflon skirt coating that the alh '98 A3 tdi engine has..what style pin bore do the aat 2.5 tdi have?..if they are bronze pin supports and teflon skirts i'm gonna order a set...any idea..tdi rs your doing it waht have you found?
thanks
Deo
ps does any one remember hereinga about a 99mm crank a few years ago from ottenger or eurospec? etc
that would be cool 99mm crank and 81,5 mm tdi pistons heheh in a a# TALLdeck tdi block!
therabbittree is offline   Reply With Quote
Old June 2nd, 2002, 06:01   #7
tdi rs
TDI(s): mk2 16v tdi
As far as i can find out the rods are the same.
And they have brass inserts on the gudgeon pin inserts.I have opened up the bowl in the top of the piston and cut deeper valve pockets by 2.5mm.
Old June 5th, 2002, 02:33   #8
christi
christi's Avatar
but I assume that you only need do that if you're gonna use a fancy camshaft, right?
Old June 5th, 2002, 11:11   #9
tdi rs
TDI(s): mk2 16v tdi
Yup i'm kinda forced into it really,i think the compression will drop a little too much but i'll be able to run more boost then!!
Old June 6th, 2002, 04:06   #10
rwolff
TDI(s): None yet
Fuel Economy: 35 MPG gas/6 MPG diesel
Sorry to rain on your parade, but the pistons aren't the only things to consider. Going from 79.5 to 81 mm pistons works out to roughly a 0.060 overbore (all material I've read about hot-rodders boring out engines was in inches).
Back in the "bad old days" of loose manufacturing tolerances, cylinder blocks had thick walls to allow for core shifting. Even then, boring 60 thousandths over was pushing things. With newer (a.k.a. mid-'80s) engines, going over 0.030 risked getting the cylinder walls too thin. All this is from "big 3" V-8 engines, which are gassers. The higher cylinder pressures of a diesel make boring a riskier proposition.
Someone already bored their block? I hope they checked the specs for minimum cylinder wall thickness and verified (probably using an ultrasonic tester) that they had enough "meat" to play with - otherwise they turned a perfectly good engine into scrap metal.
rwolff is offline   Reply With Quote
Old June 6th, 2002, 13:24   #11
tdi rs
TDI(s): mk2 16v tdi
It was 1 of the things i considered but i thought the place where its gonna be the weakest is lower down the bore as the top is very thick.But i'm using s/h parts so if it does turn ****ty it hasnt cost much!!
Old June 6th, 2002, 20:15   #12
Micwal
If you do bore out the block, you might want to try an old drag racers trick. There is a compound that you can buy to pour in the water jacket that hardens/cures hard. It is used to stiffen the blocks and bores. You do not fill the block, just the lower half. The upper half of the block is still cooled and if done right the engine is still streetable. As most heat is generated in the upper half of the block, this may have limited effect of overheating.
If I remember right, I think Oldman used to build engines professionally, and may be able to give you a better insight into this. I have not had the heads off of a tdi yet, if it has an open upper block like a honda, you can weld a plate from the exterior of the cores to the sides of the block to stiffen the upper bore area. It is a shame that no hipo blocks are made by VW like GM makes bowtie blocks.
Micwal is offline   Reply With Quote
Old August 1st, 2019, 21:59   #13
jay.sejkora2011
jay.sejkora2011's Avatar
Bump?
jay.sejkora2011 is offline   Reply With Quote
Old August 2nd, 2019, 05:49   #14
[486]
TDI(s): 02 golf ALH
17 years later and you're still better off upping the boost, as the dismal extra displacement doesn't gain you much airflow while the 81mm bore limits your head gasket choices and significantly reduces cylinder wall thickness
actually, 1z uses the older head gasket than alh, so maybe there's some solution there for 81mm bore, but I kinda doubt it
[486] is online now   Reply With Quote
Old August 2nd, 2019, 05:49   #15
Mongler98
Old thread!
I've been going back and forth on my ahu build. 82mm bore with a 100mm stroker crank. Makes it s 2.2L
I'd rather go machined pistons with 100mm crank vs more bore. Current build goal is 350hp but 450 with some crazy injection
Page generated in 0.15831 seconds with 10 queries
[Output: 118.00 Kb. compressed to 97.44 Kb. by saving 20.57 Kb. (17.43%)]
