Old August 13th, 2019, 08:07   #16
T Dot
* this is a new car to me.
I just discovered this issue, and was going to post about it until I saw this thread. When I use to drive a gas car, a hiccup like this would be an indication I was in the wrong gear. Am I in the wrong gear?
Is there a fix to this, or should I just accelerate through the hiccup?
Thanks in advance
T Dot
T Dot is offline   Reply With Quote
Old August 14th, 2019, 08:32   #17
mbesemann
Originally Posted by Zabel51 View Post
I have driven about 6,000 km since installing the Diesel Geek P2015 Code Repair Bracket and can confirm that 90% of the surging/flutter in third gear has disappeared. I'm very pleased with the improvement in driveability. Waiting to see how it performs the winter, but expecting the same reduction in surging.
Good to know! I just ordered one. Even if it does not fix the issue for me it is a good preventative fix for the p2015 error code anyway. I will provide an update if I notice a difference.
mbesemann is offline   Reply With Quote
Old August 14th, 2019, 20:39   #18
nucklehead
nucklehead's Avatar
Fuel Economy: 37
Well, if this is a built in bug, why didn't my 2013 Jetta TDi w/DSG have this surge/miss? I haven't noticed this hesitation lately, but I have installed a Kerma tune. It's Miata weather around here. Since this is likely to be present once the temps cool down I figure it's something I'll just live with. Mine doesn't hesitate all that badly, but is felt. Seems like it's those days when it's cooler in the mornings, like around 50F or so and the engine isn't warmed up yet.
Current Garage Queen - 1993 Miata Soft Top
Current Daily - 2013 Golf TDI/DSG
nucklehead is offline   Reply With Quote
'12 Golf TDI Bucking/Stuttering/Stalling Kookookachew VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 February 25th, 2015 21:40
engine bucking low rpm and throttle 81golfcaddy VW MKIII-A3/B4 TDIs 7 October 23rd, 2010 14:40
Engine cuts out at 2k RPM, local mechanic is lost... mrbiodiesel111 TDI 101 15 October 2nd, 2006 13:32
Engine speed oscillating/bucking at low RPM? Betzel VW MKIV-A4 TDIs (VE and PD) 2 April 23rd, 2005 14:39
Engine Misfiring - > 2K RPM and at Partial Load GotDiesel? VW MKIV-A4 TDIs (VE and PD) 7 February 8th, 2004 20:05
Page generated in 0.16934 seconds with 13 queries
[Output: 59.94 Kb. compressed to 54.51 Kb. by saving 5.43 Kb. (9.06%)]
