Old January 17th, 2019, 08:37   #511
Franko6
I see the cylinder head picture is quite small... not sure what happened, but if you clic the mini-picture, you can see it full-size in my photo gallery.
BTW: As we are like to do, I welded up that nasty messed up cylinder head and it came out quite good. Not perfect, with a few small pin holes and a rough edge I'd call cosmetic, but a fully functional cylinder head.
As for that being a usable part, and what all has transpired, I think there is some consideration back to the mechanic, at least.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old February 20th, 2019, 09:34   #512
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
I'll agree that, that is FOD. Piece of a blown turbo that was lodged in the intercooler perhaps? It would be small enough to make it through for sure.
Sucks either way but short of replacing the $300 part you run a risk.
Hope you're feeling better Frank. Injuries like that suck.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old February 21st, 2019, 13:19   #513
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
A bit of an interesting couple of days past, but here goes.
The pictures for Curious Chris' 12,000 mile head with FOD (foreign object damage). You have already seen most of these Chris. I know you are putting this on me, but the cylinder head tells the story.
This picture shows a dent in the center of the initial damage. The intake valve was sheared off in a single piece, which then shattered into several smaller pieces. The deep dent could not be caused by the valve material itself and it also had a cylindrical shape. The subsequent damage of pieces of valve seat striking the cylinder head and valve show much less denting as the FOD. There are many other impacts that you can judge are the FOD making it's dents before exiting. No object was noted or found upon disassembly.
The shape and size of the FOD are clearly visible, as shown in the following pics.
These two pictures show the depth of the impact and the distance of a single piece broken off of the valve's seat area.
This last picture shows the FOD damage on the intake valve near the 2:30 position. The impact crossed both the valve and the bottom of the cylinder head. I don't know what the foreign object is, but I believe it is not any VW part or piece.
So, Chris, to finish this story, I was told I 'made a bad cylinder head' and you wanted something of value in exchange for it; a turbo as I remember. In warranty disputes, I always have done the same thing. I send a pre-paid UPS shipping label and examine the part. I don't recall the exact date I sent the label, but it was months before the cylinder head was returned. I admit, same as with Bryan, I have been swamped, but when you prompted me, I got the cylinder heads, the original one, that had valve leakage, and this one, which was destroyed, and did my analysis.
I did find the original head had a valve that was spinning out of round. I vacuum test heads, so I don't know If I missed it or not. I will not debate that, but then Nick showed up over a year ago, about 2 weeks after my wreck and picked up this replacement head. I am guessing it was about the third week of October, 2017. Then, I believe it was about 7/2018, I got the report the cylinder head destroyed itself and you wanted compensation. I made the label and then started waiting for stuff to show up. The cylinder head showed up in November, 2018.
If I had not seen the cylinder head, which you seemingly thought was not needed to be sent, I would not have found the FOD damage. All claims for warranty must follow protocol. I have the right to inspect the damaged item before determining validity of the claim. In this case, I find abuse by foreign object.
But I am sure you still want to lay the blame on me.
In all of the cylinder heads I have made, and people know, it's thousands, I have few failures. Admittedly, there have been some. Overall, people also know we back our product, but do not cover abuse.
Sorry, Chris. I would have liked to work with you, but I will not accept your claim. I am not, nor have I ever blamed (Nick, Greengeeker) for the cause of this damage. I have no way of knowing how the damage occurred,
It is not reasonable, as you claim, that a foreign body stuck in the head from the time I built it, only to fall out after at least 6 months and 12,000 miles.
Don't feel bad Frank. I have crap like this happen sometimes too. It's always the fault of the technician, no matter what and no matter what the mileage or time.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old February 28th, 2019, 18:04   #514
turbovan+tdi
turbovan+tdi's Avatar
That's FOD damage for sure. Looks like a screw or something, probably fell in the engine when being installed. Sadly, sh#t like this happens,
1984 6.2 Diesel Get A Way van, remote turbo setup designed/installed by me, burning anything that burns.
2003 GSW, 2.0L ALH, Stage 2 Colt Cam, 1756 turbo, auto, silver, 380k-Wife's.
2004 GSW TDI, blue, 5 speed-DD-Malone stage 2, no kitty, aeroturbine muffler, PD150's.
2003 JSW 1.8T, silver-parting out. 2006 JSW, TDI 5 speed, blue.
turbovan+tdi is offline   Reply With Quote
Old February 28th, 2019, 18:38   #515
WildChild80
WildChild80's Avatar
Did the valve loose it's angle or is that valve seat mated to the valve? If it lost it's angle/mating surface, could it have melted, and then pieces broke off and made it back to the seat surface?
WildChild80 is offline   Reply With Quote
Old March 16th, 2019, 23:39   #516
Franko6
WildChild,
The obvious sign that there was FOD is the circular impression that crossed over from the valve seat to the cylinder head, causing a fracture on the valve seat. The seat was basically chopped off, in a shearing force, which by the way, I can only imagine happened at high speed.
Thank you, those who can see the same thing that I do. Although the other complaint, who decided to install a junkyard engine, has not responded, he and I came to a quick agreement. I guess the settlement suited him, as he has now, no complaint and also, no comment.
I will continue as I have before. Trust and verify.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old April 1st, 2019, 08:10   #517
jasonTDI
jasonTDI's Avatar
Posted at FRANK06
While I stand by hoping you are feeling better I cannot abide by the continued trash talk you do, of me, to my clients that call you looking for parts. I STILL hear it from recent customers that may or may not have bought parts from you recently. Jesus man....just stop with the BS. For F**** sake grow up.
Old October 2nd, 2019, 13:47   #518
Nero Morg
Nero Morg's Avatar
Well I guess it's my turn to share a tale here.
I had ordered a hotswap set of injectors through Kerma a few months back. Payment was easy, got the injectors in a timely fashion, sent in my cores and got my deposit back.
About 2-3 fuel tanks later, I noticed a significant drop in fuel economy. Sure I was expecting some with larger nozzles and a tune. But not going from 42mpg to 28, along with excessive white smoke 24/7. So I did what I always do on these forums. I read. A lot. Spent days pouring over the forums for a resolution. Between grandma driving my car, having DFIS rebuild my injection pump, (which, surprise, didn't need it) even going to the extent of emailing graphs to Malone. They said boost and air readings looked great. Issue lied elsewhere.
So did more reading. Dropped my IQ as far as 8 trying to help. No dice. Finally got ahold of a vendor, who found out my injectors I hot swapped were out of balance. Badly. So I sent them to him to get them repaired. I had done this, because unfortunately there are several other members here whom I've read had a very similar experience, and I didn't have the time to swap injectors repetitively. I initially wasn't going to seek out any compensation, but I was suggested to by another member.
So I called Kerma up yesterday, and I tried to explain my story. As soon as I got to the part where I said I sent them to another vendor for repair, he was immediately on the defense about the subject. It took me several times to finish explaining the situation, even one point of even asking him to stop interrupting me. Once I was done, he then proceeded to use scare tactics saying that if anyone other than Kerma builds their nozzles, there's a high chance that the nozzle will overheat and literally blow the tip off causing catastrophic damage. He also said all other nozzles that all other vendors sell, per verbatem, "are all garbage in comparison. Firad, titans, Wutzen. We sell the absolute best, and we are the only ones who know how to build them."
Ultimately I was denied any type of compensation, and was told to get ahold of someone else at Kerma to get anything. I'm not interested in jumping through hoops like this to get compensation for chasing my tail trying to fix my car. After the poor customer service I received, I don't want an in store credit or discount on any of their parts anymore.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is online now   Reply With Quote
Old October 2nd, 2019, 13:55   #519
WildChild80
Well, I called Kerma today to swap my tune to another car, was told that I had to have a new tune but they'd do it for 300...no thanks, I'll just swap the ECU and deal with the skc issue...I've got a vagtaco so it'll just take a few minutes longer.
I'll pay for a new tune if I want to tune a second car not to swap to another car with the same hardware
Page generated in 0.19299 seconds with 12 queries
[Output: 101.28 Kb. compressed to 87.79 Kb. by saving 13.49 Kb. (13.32%)]
