Evripos
I own a 2012 VW Passat Tdi SEL with 78,000 miles. The transmission fluid was last replaced at 65,000 miles. The car for quite some time has been making a grinding sound as I come to a stop. It is not the brakes because they are only ~ 2,000 miles old. It does not do it while the car is cold. It does get worse in stop and go conditions. My only solution so far has been to modulate the brake pedal and being very light on it. I drive as if I carry eggs about to break. If for any reason I hit the brakes the grinding sounds more like a vibration and it is a lot louder. Coming to a stop by having the transmission in neutral does nothing. The grinding noise is there. THe transmission shifts smoothly up and down. There are no jerks, clunks or any other symptoms I can point out. There are no codes.
Does anybody have any idea what is going on here?
Thank you.
Thank you.
