whats that mean "runaway" are you implying a safety issue?
When a Diesel engine gets to the point where enough oil is leaking into the cylinders, if it has enough compression to run, it can, and will, run on it's own crankcase oil, bypassing the fuel system, engine management, ignition switch etc. Shutting the key off does no good because your key does not control how much oil a worn engine pumps into the cylinders, and said oil does not need your key's permission to burn in your engine. So what happens is the motor runs on its own oil until there's none left, which incidentally destroys the motor before it's over. And yes, it's a safety issue because the car can suddenly charge forward without warning.
Anyway, a gulp of oil is enough to bend rods. Use enough oil and it will runaway. So I'll ask again, how did you determine that all of the oil that is disappearing from your crankcase is doing so via one cylinder? As VeeDubTDI mentioned, if the oil seal in your turbo is leaking that much, you're at risk of a runaway and bent rods, if it hasn't happened already.
