Salmonbum
So my BRM is cranking very slow in morning and its not that cold, only about 27 F. Car has 335,000 miles. The battery is testing good proper amps and a load test shows its solid. The starter is still original which has me pointing to that. But once it does start it's pretty easy to fire back up. I am assuming the weak starter is having issue with cold motor, oil, etc.... Am I on right track? Other than that car is running great. I did recently replace the engine harness but it was doing this before, just not as bad but was not as cold either.
