Your tuner should know...
But some of them just play with numbers, not knowing why.
Its simple: if the old said 2600
then its 4160
(3 bar would be 3120)
If 2500, then its 4000. (some ecu calib map at lower max v)
(3 bar would be 3000)
200 stays 200.
Hmm very interesting. Thanks for letting me know. I'll try researching some more about it. When you do have time, I'd love to learn about those other n75 maps.Simplest way is to lengthen your vnt actuator..
Or find the n75 max table and decrease it. Not at home so I can't show you where it is.
The n75 table you speak of doesnt handle transient spikes but is a guide for steady state load.
Theres also a setting for time above pressure when limp hits. what is your svbl set to btw?
try the rod adjustment.. if u can check where it cracks n hits the stop.. should be 4-6 crack, 18-22in hg stop. the second number is more critical
Ahh yeah, the 3 bar map definately wouldn't help.
Your map can do up to 2500 mbar, and you aren't even close to that!
you might want to set the svbl a bit higher...
2172 is 17.23 psi (at sea level)
2250 is a bit too close... 18.38 psi.
In most stock ecu's and my previous tune I saw around 150 mbar higher svbl than max, which gives room for the boost control (and not hit limp quickly).
If you use 150mbar, use 2332 mbar, which is 19.58 psi...
Or conservative 100mbar would be 2282 mbar, which is around 18.85 psi.
2 types of limp, one is exceeding svbl, and the other which is less strict, exceeding request boost for x time. You might be tripping svbl too easily.
But the actuator adjustment is really critical. Think of lengthening the rod as shifting ALL the n75 controls to be less "extreme".
For the n75 max vane adjustment by PID (control loop that handles spool up), search inside your maps using vagedcsuite a value of 7500 or 5500 (I see in 03 GN ecu address 5645c- but yours may be different). It's a 2d table, axis rpm, and values are the raw value of percent n75 (eg 7500-> 75%, which is actually 25% in vagcom/vcds)
You can tweak it a bit, in your case of spikes at 2500-3000, lower those values to 7000 lets say, and also 3250 and 3500 to 7500, as you want it to smoothly taper down.
It's how I handled some areas of spikes on my tune (after double checking my actuator was set ok!)... I learned that the normal n75 map didn't do much at all.
Please please do check the actuator. Being with less restriction I would aim for hitting the stop at around 22 in Hg, which is what I use on VNT17, with a high flow cat.
Check my other posts here, a bunch of us put up how to do a few interesting things. Also on ecuconnections.com with the same name. I forget the tdiclub thread name right now.
You can PM me.
Ok, wonderful. Today I did a lot of logging, after flashing again.Adjusting the rod is better because you give more spring force which is used to open vanes.
2200 is not dangerous for vnt15... most tuners use 2250 or so for vnt15 request (18 psi).
The vnt 15 compressor map allows 2.3 bar in mid range btw... taper down boost past 4k... I posted my calculations somewhere in the "help me understand my ecu" thread.
Not to say that you don't have an issue with the N75/actuator/vanes, but this ECU only has one N75 map per coding section. Later cars sometimes had two, or were even gear dependent (5+ N75 maps). If you want the same boost pressure in varying load conditions (as in different gears) the duty cycle may need to be different. So, there is always going to be some variation.Ok, wonderful. Today I did a lot of logging, after flashing again.
I think I've come up onto something.
Sometimes the boost requested and actual boost follow each other PERFECTLY. I mean it doesn't even overboost very much. Tiny spike (40mbar), then drops down and raises to hold 2172mbar right next to requested. Maybe TOO well controlled.
AND SOMETIMES (at random) it spikes hard and holds actual boost higher than requested (ex: requested 2182, actual 2280-2300, after large spike) and doesn't keep to the line very well on the graph. The reported N75 duty cycle goes up to 93% to try to correct it, but never manages to bring it down.
Seems like something is acting up sometimes.
I'm going to check my N75 valve first. Is there a way to clean it? Does it get dirty?
Yes, I understand what you mean. But that variance was happening at the same RPM, and same gear, just different times. Either way, my vanes have been cleaned, actuator works well, and now I just cleaned my N75 valve and lubricated its insides, moves very smoothly and it works. Will log tomorrow.Not to say that you don't have an issue with the N75/actuator/vanes, but this ECU only has one N75 map per coding section. Later cars sometimes had two, or were even gear dependent (5+ N75 maps). If you want the same boost pressure in varying load conditions (as in different gears) the duty cycle may need to be different. So, there is always going to be some variation.
