Put it on the lift, changed the oil and mounted winter tires. Went to leave and it would start and die instantly. Found a YouTube video about disconnecting the battery lead for a couple minutes. It worked, the car started right up and I took it home. Why did it do this? I have noticed the five year old battery cranked a little slow on the first cold morning? Is low voltage a possibility or is it time for an immobilizer delete? I can't have my wife and daughters driving this thing if this is going to be a regular occurrence. Also, once it is running, can it die because of this? Thanks
