phreaddy
- Joined
- Jul 31, 2009
- Location
- Houston, TX
- TDI
- 2015 Golf hatchback (purchased used in December 2021 to replace the 2015 Sportwagen (purchased new in Sept. 2017) that I totalled. :( Former TDIs: 2006 Jetta sedan (FLOODED -- Thanks, Hurricane Harvey); 2009 JSW (FLOODED-- thanks, Hurricane Harvey!)
I generally take my 06 Jetta TDI to the same Shell station. That past two visits, I couldn't get either of the diesel pumps to start pumping. It's as if the venturi effect was engaging the shut-off just when I started squeezing the nozzle trigger. The clerk (same one both times) said no one else has had any problems. I ended up going to another station both times. Could there be something wonky inside my filler throat causing the nozzle to cut out?
