Thanks, excellent write up, I forgot to check your site, sorry !
I am still a little confused.. I think I may have names/terminology mixed up.
My plan was to support the engine, remove the M8 nut from the top of the old rubber mount, then carefully lift the engine. From what I have read, the engine cannot be lifted enough, so I was also planning to remove the bracket from the engine (the bracket that mounts to the top of the mount).
VAGCAT listed these bolts as M10, but shows two different lengths.. 30mm and 40mm ? what torque ?
And, if you don't mind me asking, where did you get your torques from ? as I still cannot find any mention of these mounts in my Bentley.
Once the engine bracket was out of the way, I can changeout the mount..
I would like to avoid dropping the subframe, don't want to get into alignment etc...
