shoebear
- Joined
- Aug 1, 2002
- Location
- Colorado Springs, CO
- TDI
- 1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
My 2003 currently has 306K miles. I want to chip it and add big injectors, but I'm trying to work out all the niggling issues to make sure it's sound before I add power.
I've resolved 2 of 3 such issues. The one left is a high-frequency noise generated when engine braking at about 3000 RPM or greater. I recorded this noise so you can help me identify it. To do so, I descended an 8% grade in 3rd gear at about 45-50 MPH, which puts the engine at about 3000 RPM. The noise goes away if I gently blip the accelerator, and comes back when I take my foot off. You can hear the noise coming and going as I do this. I made the recording with the windows down, an there was terrain & a guard rail reflecting the sound back at me, which made it easier to hear.
The first video has no audio filtering. You can hear the noise, but only just barely and if you know what to listen for. In real life, it's easier to hear it. In the second video, I used Audacity to apply a hi-pass filter to make the noise stand out.
If you have high-frequency hearing loss, you may not be able to hear the noise at all.
My WAG is valve float, the noise being valve stem striking the lifters when they end the float? But this is an uneducated guess.
No audio filter--
https://youtu.be/EUc8-Uz_Jxg
High-pass audio filter--
https://youtu.be/teg2NqwJvxM
No audio filter--
