Old October 4th, 2019, 13:54   #1
cbass
TDI(s): 2003 Wagon
Default installed 17/22 and computer w malone
Car is not making boost.
  • MAF Deadlined at 35x plugged in and 55x unplugged
  • car is requesting boost but not making it.
  • Haven't installed 3 bar yet (will do tomorrow)..
  • reclocked the turbo from up position (towards intake) to down position like factory when i received it.
will any of these affect boost?
Malone stage 5
520's
11mm
etc
cbass is offline   Reply With Quote
Old October 4th, 2019, 14:12   #2
Nero Morg
Nero Morg's Avatar
Is the ecm you installed programmed for a 2.5 bar or 3 bar map? It will make a difference. Also, what hardware is your ecm tuned for, and is what you listed the hardware that's installed? Is it really a stage 2 Malone?
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is online now   Reply With Quote
Old October 4th, 2019, 15:24   #3
cbass
TDI(s): 2003 Wagon
tuned for a 3bar. the computer is tuned for the same hardware i have + egr delete & immo del (which is done i just dont list as a mod)
Old October 4th, 2019, 15:39   #4
BustedBolts
Fuel Economy: Mid 40's
You HAVE to match the map sensor to the calibration in the ecu for proper turbo operation.
01 golf, 02m 6 speed, engine internals stock, R520 11mm IP BEW lift pump, td05h turbo 36 to 38 psi, fmic with 2.5" piping. My custom tune. <> 02 golf, 02m 6 spd, DKM clutch, rosten h beams, R520 11mm IP, bew lift pump, HE221w turbo 30+ psi, large fmic with 2.5" piping, My custom tune.
BustedBolts is offline   Reply With Quote
Old October 4th, 2019, 15:41   #5
cbass
TDI(s): 2003 Wagon
thank you sir. 3 bar will be installed tomorrow.
Old October 4th, 2019, 17:39   #6
Nero Morg
Nero Morg's Avatar
Yeah definitely have to install that with it, otherwise it'll be a dog turd on power with no boost, cause it thinks it's getting all the boost, when it isn't.
Old October 4th, 2019, 20:14   #7
cbass
TDI(s): 2003 Wagon
thank you gentlemen.
Old October 5th, 2019, 13:50   #8
arazvan2002
arazvan2002's Avatar
If after you install 3bar sensor it doesn't make boost, take a look at what you have changed when you reclocked the turbo. Check basic settings on channel 11 to see if you have at least 100mbar difference (ideal is like 120+).
A4 B6 1.9 TDi AVF quattro - development in progress: remaped, GTB2056VL. ARL inj, FMIC, 320/288mm B7 brakes, OEM Sport suspension, B7 Steering wheel MFSW.
arazvan2002 is offline   Reply With Quote
Old October 5th, 2019, 20:29   #9
cbass
TDI(s): 2003 Wagon
Will do
Old October 11th, 2019, 16:40   #10
cbass
TDI(s): 2003 Wagon
Everything is good. 3 bar worked.
1Z VNT 17/22 Downpipe,10, 12 IP's, Febi mounts, stock computer skilyleski Private TDI Items for Sale/Wanted 14 March 31st, 2016 08:34
Got the VNT 17/22 installed now what :) tanner199 TDI Power Enhancements 15 September 29th, 2014 04:45
vnt-17/22 installed hoses don't line up DieselingDean VW MKIV-A4 TDIs (VE and PD) 3 September 1st, 2011 21:50
VNT 17/22 Hybrid Turbo and PP Downpipe Installed QQQ TDI Power Enhancements 0 August 20th, 2011 19:54
Drove my Malone Stage 4, 17/22 PD100 today... VWBeamer TDI Power Enhancements 32 November 24th, 2010 02:41
Page generated in 0.15058 seconds with 11 queries
[Output: 93.97 Kb. compressed to 79.40 Kb. by saving 14.56 Kb. (15.50%)]
