tongsli
Well, if I had a reciprocating saw, it would have gone much, much faster. I used(please don't laugh) a drywall saw which I put into the split rubber. I tried a drill (without much luck) then managed to put a three jaw puller on the center piece and pushed the rubber 99% out.Lito,
What did you use for an extractor / tool of destruction to remove the old bushing?
Were the urethane replacements in segments and any easier to install?
One wack with my chisel and it popped out. Then I struggled with the metal insert with a dull hack saw blade and used my sledge with a chisel and wacked on it some more.
Finally got the metal insert out. I now have a loaner 18V dewalt saw which should make it much, much faster to destroy the other side.
Here is the new bushing which I used a bearing press to install the center piece and then just put the ends on by hand. Took 15 minutes.
http://www.ecstuning.com/ES261061/
Energy suspension bushings;
http://www.energysuspensionparts.com/15.3118
These look the same;
http://www.amazon.com/Energy-Suspen...1434855346&sr=8-3&keywords=rear+axle+bushings
As are these, energy suspension bushing;
http://www.ebay.com/itm/Rear-Axle-B...-31-/360991819218?hash=item540cca05d2&vxp=mtr
With just one side installed, it feels like I have 1/2 a sway bar in the back of the car. Very happy with it. No more bone jarring bumps/crashes on that side. Just need to get the other side installed.
I'm confident I can get it done faster now.
